Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 11-30-2008, 03:34 AM   #1
Coaxial install.
Here is some pics of my almost completed coaxial setup.
Coaxial install.-100_4934.jpg   Coaxial install.-100_4937.jpg   Coaxial install.-100_4936.jpg   Coaxial install.-100_4935.jpg
rgsgww is offline   Reply With Quote
Old 11-30-2008, 07:07 AM   #2
Coaxial install.
Where do those grounds go? Is that a power injector in the lower left?
jerryh3 is offline   Reply With Quote
Old 11-30-2008, 11:54 AM   #3
Coaxial install.
The grounds head back to the closest point of ground, the ground bus bar.
Lower left is a power supply for the amplifier, its plugged in to a surge protecting receptacle, which is protected by a gfci to meet code.
Its almost done, that orange cable in the lower right picture is the soon to be hooked up rg/11Q
Old 11-30-2008, 12:11 PM   #4
Coaxial install.
Is the two way splitter going to a cable modem? Do you have a schematic for the entire system?
Old 11-30-2008, 01:15 PM   #5
Electrician
Coaxial install.
Whats with all the redundant grounding? The outer conductive shield of coax needs to be grounded as close to the point of cable entrance as practicable, most likely your cable supplier already did that outside at the demarc location.
chris75 is offline   Reply With Quote
Old 11-30-2008, 02:59 PM   #6
Coaxial install.
The coaxial is grounded with a ground block (as seen in one of the pictures)
It is burial and enters the structure from the inside.
I'm kind of a ground fanatic...I might just remove all of the unnecessary grounds...they are in the way.
Old 11-30-2008, 03:09 PM   #7
Coaxial install.
Yes, and I'm going to make one right now.
Old 11-30-2008, 04:34 PM   #8
Coaxial install.
Why the isolator? Is that a Holland?
Old 11-30-2008, 06:21 PM   #9
Coaxial install.
I got bad 60hz interference (you know, the rolling bars or wavy picture) on some channels, I checked the ground in case that was it.
Its all viewsonics equipment except for the lightning arrestor, thats hyperlink technologies.
Link about the isolator
http://www.broadbandamps.com/Product...ndIsolator.htm
Old 12-11-2008, 11:49 PM   #10
Kyle Emerick
kemerick's Avatar
Coaxial install.
You must have a very nice image on your screens... I am jealous.
My constant project is my home which was built in 1947. I have remodeled almost all of it and am in the process of finishing off a 1000 square foot addition. Lars Construction got me up to drywall and I am doing the rest. You can see many galleries of it
under Galleries and then House.
kemerick is offline   Reply With Quote
Old 12-12-2008, 08:21 AM   #11
Coaxial install.
Not the best though...Some improvement with a new coax drop. Could be better.
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 08:56 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Can I install 3/4" HW on top of the rolled floor membrane there now? davevarga Flooring 3 03-09-2008 11:16 PM
