Chris The DIY Guy Vs. "The Ranch" - Project Showcase - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 10:17 PM   #46
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Contractor came and brazed the lines, charged the system and ran a test so the North Side heat pump is up and running! Whoo Hoo! Now I get to tweak my software to get the most efficiency out of both units. Will use the TED 5000 to determine if there is any potential savings putting similar system in the South Side of house.
Started on the bamboo floor, this was surprising. It turned out to be a lot easier than I thought, but it's taking a lot longer than I thought. I am currently in the bulk of the floor, most of the time today was spent cutting the floor around the flush registers. Will encounter the fourth tomorrow, a bit easier since it's perpendicular to the floor slats.
Photo tomorrow 5/13/10
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 05-17-2010, 11:12 AM   #47
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Almost there!
...with the floor...
This is where I had completed the floor as of Friday 5/14/2010. I am have completed as much as can be done with the pneumatic nailer and will be finishing by hand nailing. The Advantium also arrived today 5/17/2010 so will be picking that up so can move quickly to installing wall cabinets and installing the Advantium, then begin painting the baseboards and door casings.
If the weather holds up will need to complete the exhaust duct to the outside this week.
--Chris the DIY Guy
Old 05-19-2010, 10:54 PM   #48
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Bamboo floor completed today 5/19/10 at 12:55pm. Started right away into wall cabinet installation. One more cabinet to hang and will move to basement to complete range exhaust. Hopefully that's a single evening project. Although the only place I found duct support brackets was Menard's and they don't accept Am-Ex. As a result don't shop there too often.
Will need to order the kitchen sink, it has to be built into the sink cabinet.
Rain & T-Storms all week...
--Chris the DIY Guy
Old 06-12-2010, 01:36 AM   #49
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
How about some new pics? dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 06-13-2010, 10:38 PM   #50
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Yeah I know, every time I have time to take photos it's stormy or raining. Will post tomorrow evening.
--Chris the DIY Guy
Old 06-14-2010, 05:43 PM   #51
Still going...
ChrisDIY's Avatar
Rewards Points: 508
The new HVAC unit is complete! See first photo. A new local HVAC contractor came in and ran the lines outside to the condenser unit. I put in the condensate pump to the outside until I am able to move the utility sink back into the basement and install the Hartell LTA. The unit is very quiet and compared to the older unit in the south half of the house and cycles far less. I posted a question about this and the consensus is that its not because it's a new unit. Will need to figure out how to overcome the strange return vent location the original owner constructed. See second photo. Short of tearing out a wall and running a vent to the ceiling we are having to run ceiling fans constantly to even out the upstairs and downstairs. As you can see the ceiling on the second floor is a cathedral type which only magnifies the problem. The return is in the top and (I added) in the wall of the closet where the air-handler is. Lower right in photo.
Chris the DIY guy vs. "The Ranch"-img_2694.jpg   Chris the DIY guy vs. "The Ranch"-return-problem.jpg
--Chris the DIY Guy
Old 06-14-2010, 05:52 PM   #52
Still going...
ChrisDIY's Avatar
Rewards Points: 508
The kitchen wall cabinets are about 90% done. I need to tidy up the wires for the "in cabinet" lighting and place the decorative trim across the bottom of the cabinets. I have to finish the base cabinets after I put up the Durock Tile Membrane for the back splash. I have installed the Advantium oven and its working beautifully! With the ceilings as they were constructed I had to cut a hole through the floor into the basement to run the exhaust to the outside. I wound up making my own duct support.
Chris the DIY guy vs. "The Ranch"-img_2681.jpg   Chris the DIY guy vs. "The Ranch"-img_2683.jpg   Chris the DIY guy vs. "The Ranch"-img_2688.jpg   Chris the DIY guy vs. "The Ranch"-img_2689.jpg   Chris the DIY guy vs. "The Ranch"-img_2692.jpg
--Chris the DIY Guy
Old 06-14-2010, 05:59 PM   #53
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Along the way I put in two ceiling fans on the second floor. Beforehand the upstairs was 15 degrees warmer than downstairs and we hadn't had any real hot days yet. I also installed the front porch's ceiling fan and also closed up the openings in the sides and front where squirrels were entering. You can see the new wood in the photo.
Next photos will be after I get all the base cabinets in. Have one more to pick up. No store locally has the Durock Tile Membrane so will order online.
--Chris the DIY Guy
Old 06-14-2010, 07:04 PM   #54
Registered User
Rewards Points: 5,516
Remember to keep your exhaust duct terminations 3' minimum from a window opening, door, or supply opening (furnace supply, etc.) to the house. You probably already strapped your water tanks against seismic movement, and run the TPR valve discharge down near the floor.... Looking good.
Be safe, Gary
Old 06-14-2010, 07:55 PM   #55
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Be safe, Gary
Uh, Oh! I thought that only referred to exhaust from a combustion source like a furnace, boiler or water heater. A little late to move it. Those water heaters are not being used and I really need somebody to haul them off. They did work, now on Rinnai tankless. I probably should get them out of that room and eBay.
--Chris the DIY Guy
Old 06-15-2010, 09:22 PM   #56
Registered User
My mistake! I was researching it from memory, and...... It was bathroom fans I was thinking about. If you ever use a hood fan around vinyl siding, I suggest some trim to keep the two far apart. I had a family of raccoons in my attic for a winter..... I know what you are going through!--- lol.
Be safe, Gary
Old 06-25-2010, 10:50 AM   #57
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Will be placing order for the kitchen sink today. Will need to build a support structure in cabinet for it. Although the sink is an under-counter sink it doesn't attach to the counter-top with clips. I would guess it's because the sink is cast iron.
I also need to start building the support structure to put underneath the oven cabinet. Specs require a support that can hold 200 lbs! That's a big turkey! Actually the oven empty weighs 190 lbs. Wow!
The door casing I chose to put throughout the house turns out to be special order in Oak. So once I finish kitchen (using painted Poplar) will start the arduous task of replacing all the casings and trim.
--Chris the DIY Guy
Old 06-25-2010, 11:48 AM   #58
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Also, on the list is closing up the unfinished soffits. I will need input on squirrel and raccoon behavior to determine if I can wait till fall since now wasp are everywhere!!! I'm not looking forward to working on the very steep roof either. I'm thinking I will need to rent a bucket truck...
Found out the "roof closet" being an unconditioned space is contributing to the increased upstairs temperature. Used spray foam around door frame and this has reduced heat transmission. See pictures in post #3
EDIT: Isn't this incorrect? If this space is not conditioned there shouldn't be insulation on the walls right? I have no intention of converting this to a conditioned space, previous owner might have? Is there any other reason walls would be insulated? The interior of the roof on the other side has blow in insulation in it so there is more than likely insulation below the roof in the roof closet.
--Chris the DIY Guy
Old 06-25-2010, 07:29 PM   #59
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Well, I am not going to be done by the Fourth of July
Here is where I am with the kitchen. Will need to pick up another cabinet(s) to go on the end. We have decided to plan for the Tulikivi so the peninsula end has to be ordered differently. Once I have the remaining cabinets in place will order the counter-top. Sink is estimated to arrive July 19th...
Chris the DIY guy vs. "The Ranch"-img_2788.jpg   Chris the DIY guy vs. "The Ranch"-img_2790.jpg   Chris the DIY guy vs. "The Ranch"-img_2795.jpg
--Chris the DIY Guy
Old 06-25-2010, 09:11 PM   #60
Registered User
That's coming along nicely! Don't forget to spray foam around the ducting at the rim penetration and the wires through the floor (fire-stop).
I will correct myself yet again, right the first time: "Range hood exhaust duct shall terminate outside, shall have a 3’ clearance to windows
and doors and other openings, shall be air tight and be equipped with a back draft
damper. Ducting shall be galvanized steel, stainless steel, or copper, with a smooth
interior finish. CMC 504.2 (4)"
Keep up the good work!
Be safe, Gary
Chris the DIY guy! ChrisDIY Introductions 1 02-18-2010 10:19 PM
"the edge" edge vents k.kuenn Roofing/Siding 2 06-25-2009 10:30 AM
Delta-FL "The Warm & Dry Floor Systm joedadog Flooring 4 04-11-2009 05:40 PM
My house is a project Part III "The basement" tigerbalm2424 Project Showcase 12 12-20-2008 10:53 AM
