Chris The DIY Guy Vs. "The Ranch" - Project Showcase - Page 28 - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 12:59 PM   #406
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Been tiling knew this was going to take forever...
After the Krick Krocks failed miserably switched to string a level and it's working much better!
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 10-30-2013, 01:18 PM   #407
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Just finished tiling the shower floor! That was harder than I thought...
Now on to cutting the base row tomorrow!
C.
--Chris the DIY Guy
Old 11-02-2013, 01:46 PM   #408
Still going...
ChrisDIY's Avatar
Rewards Points: 508
All base row pieces cut ready to apply, large format for under the bench.
--Chris the DIY Guy
Old 11-21-2013, 07:39 AM   #409
Originally Posted by ChrisDIY View Post
app still can't figure out portrait orientation...this is upside down? Grumble...
Attachment 70945
From page 25. I always thought the drain was best situated on the ceiling for the shower.
avengerki is offline   Reply With Quote
Old 11-24-2013, 08:10 PM   #410
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Been working feverishly to get room painted before carpet is installed Tuesday. That includes painting and installing the new bathroom door and the converging pocket doors.
--Chris the DIY Guy
Old 12-03-2013, 06:17 PM   #411
SuperJETT's Avatar
Rewards Points: 156
I haven't been on the site much but used to read through your thread. I just got caught up, thanks for still posting the updates.
SuperJETT is offline   Reply With Quote
Old 12-12-2013, 09:57 AM   #412
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Finished all the critical wall tile in the bathroom. The shower door is now laser line plumb on both sides. So glass door company should have no issues installing a steam door.
Next finish ceiling then the glass accent tile!
From 1/20/2011: This is probably the last design tweak I'll do until I get a go ahead on the plumbing rough in. It will take me a month to tile this bathroom...
Well, I've been at this now for a lot longer than a month!
--Chris the DIY Guy
Old 12-12-2013, 12:06 PM   #413
Bill Kearney
Rewards Points: 1,174
Plumb certainly helps, but what they really want is a consistently flat surface. They can measure and fit just about anything. A wall with a consistent surface that's off-level is better than a level one that uneven. Or so my glass guy mentioned to me.
I chose to put Silestone quartz around all the shower openings. You're not likely to get more flat that unbroken lengths of the same 3cm material all the way around...
Which doesn't detract from the excellent job you've done thus far. Nice work!
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
ChrisDIY (12-12-2013)
Old 12-12-2013, 12:50 PM   #414
Still going...
ChrisDIY's Avatar
Rewards Points: 508
THANKS! I'm planning on using my 6' screed to set final tile position, the Raimondi does excellent job removing lippage.
--Chris the DIY Guy
Old 12-17-2013, 08:09 PM   #415
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Just laid out accent glass tile for room length of 123" so I know where cuts will land.
--Chris the DIY Guy
Old 12-18-2013, 08:01 AM   #416
Bill Kearney
Heh, when you put all this effort into the job it's worth going the extra mile to plan cuts precisely. Nobody else would ever notice if something wasn't even, but you'd see it every time...
Old 12-27-2013, 05:52 PM   #417
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Sneak Peak!
--Chris the DIY Guy
Old 02-16-2014, 10:48 PM   #418
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Finished tiling the floor. Will be grouting tomorrow. If I can work at a steady pace from now on should be done in about a month with bathroom.
--Chris the DIY Guy
Old 02-18-2014, 10:55 AM   #419
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Floor installed and grouted. Accent tile installed and grouted.
Now on to cutting and installing base row and the tiles for shower door opening. Then final caulk and grout.
Chris the DIY guy vs. "The Ranch"-20140218_075845-1-.jpg   Chris the DIY guy vs. "The Ranch"-20140218_075918-1-.jpg   Chris the DIY guy vs. "The Ranch"-20140218_075812-1-.jpg
--Chris the DIY Guy
Old 03-13-2014, 10:38 PM   #420
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Finished the base row of tile in the bathroom. Things will speed up now toward completion. I well be cutting the tiles to finisher shower door opening them on to final caulking and grouting.
I like the tile levelling system but it leaves mortar behind the clips that you can't see but when you break them off mortar has to be cleaned. I have a few areas not sure how to cut out.
Something I would do differently would be to place a clip at the bottom of the row on the ledger board to keep spacing away from wall the same. I have the clips stuck in backwards just to keep grout space even.
--Chris the DIY Guy
Chris the DIY guy! ChrisDIY Introductions 1 02-18-2010 10:19 PM
"the edge" edge vents k.kuenn Roofing/Siding 2 06-25-2009 10:30 AM
Delta-FL "The Warm & Dry Floor Systm joedadog Flooring 4 04-11-2009 05:40 PM
My house is a project Part III "The basement" tigerbalm2424 Project Showcase 12 12-20-2008 10:53 AM
