Chris The DIY Guy Vs. "The Ranch" - Project Showcase - Page 25 - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 10:30 PM   #361
Still going...
ChrisDIY's Avatar
Rewards Points: 508
app still can't figure out portrait orientation...this is upside down? Grumble...
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 05-16-2013, 09:29 PM   #362
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Ok, let's try using PC
--Chris the DIY Guy
Old 05-17-2013, 10:02 PM   #363
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Deck mud pre-mixed and ready for water. Last bag of sand was a little damp not sure if it will mess
things up so will dry mix and use this first tomorrow.
--Chris the DIY Guy
Old 05-18-2013, 06:02 PM   #364
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Now THAT was a two person job! Took me almost three hours between mixing, filling and levelling. Not to mention walking from the garage to the shower with a 5 gallon bucket filled with deck mud.
--Chris the DIY Guy
Old 05-18-2013, 07:10 PM   #365
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 352
Looks good Chris.
Is that spider shaped rail thingy a guide for your dry pack? That is dry pack, right?
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 05-18-2013, 10:31 PM   #366
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Yes it's the Quick-Pitch by Mark-E Industries. Got mine on Amazon. They have a whole system.
--Chris the DIY Guy
Old 05-29-2013, 10:05 PM   #367
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Finished application of Hydro Ban. Next step tiling. Ceiling then walls.
--Chris the DIY Guy
Old 05-29-2013, 10:53 PM   #368
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
Looking good!!
The Following User Says Thank You to Windows on Wash For This Useful Post:
ChrisDIY (05-30-2013)
Old 05-30-2013, 10:00 PM   #369
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Since I am a person who always plans ahead I realized I made a critical omission. I was looking at the LED driver and realized they come in either 20 watts, 60 watts or 6 x 50 watt taps. I only ran one pair of wires but will need to run another pair. The planned lighting will be 90 watts. Thank God!
This would have been a costly thing to fix later!
Since I will have 4 taps open I have to see if there is another location in bathroom I want to put another set of LED strips that will be on same switch.
--Chris the DIY Guy
Old 06-06-2013, 11:49 PM   #370
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Finished cutting ceiling soffit pieces ready for dry fit. Have a pretty bad cold so not able to work on things. I have two major things to work out. Making sure I have adequate overlap for the rain panel and also that the final thickness will be sufficient. Planning on a 1/4-3/8-1/4 trowel.
It's pretty tough working and measuring upside down. I also hope my mortar is sticky enough to hold this tile up until I can get a prop underneath.
I'm getting there...
Sent from my Samsung Galaxy Tab 2 using DIY Chatroom
--Chris the DIY Guy
Old 06-08-2013, 04:24 PM   #371
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Introducing the clearly not approved upside-down Chris DIY-Raimondi ceiling levelling technique.
That was tough! One thing I will need to keep in mind is making mortar a tad bit drier it seemed a little soupy and didn't stay up when applying although this may be my experience level too. Mixed at middle of ratio on bag.
--Chris the DIY Guy
Old 06-08-2013, 06:59 PM   #372
Bill Kearney
Rewards Points: 1,174
Best advice I got regarding ceiling tiling was 1) get someone else to do it, 2) wear a hat, 3) keep your mouth closed (because thinset tastes terrible). I didn't have to support the 12x12's I put up, mainly because I didn't make the thinset too thin and I back-buttered them properly. The grooves from a notched trowel help form a bit of a suction as it squishes. At least that's how it worked for me.
Just be sure to double and then triple-check that you've gotten all the haze off the tiles. Those last little bit of it will drive you crazy a month from now... It's even less fun using acid to get that off there, above all the other nice work below.
wkearney99 is offline   Reply With Quote
Old 06-08-2013, 08:16 PM   #373
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Originally Posted by wkearney99 View Post
3) keep your mouth closed (because thinset tastes terrible)...
LOL, funny you should say that, missed my mouth by inches!
--Chris the DIY Guy
Old 06-09-2013, 10:12 PM   #374
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Tried in the rain panel and it fits perfectly! Whoo Hoo!
Next step is tiling the bottom of the recessed area or the "real ceiling" around my soffit.
--Chris the DIY Guy
Old 06-26-2013, 01:31 PM   #375
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Installing bench and anchors are stripping cement board. Ran out and bought a different style that doesn't require anchor to turn to seat
--Chris the DIY Guy
Chris the DIY guy! ChrisDIY Introductions 1 02-18-2010 11:19 PM
"the edge" edge vents k.kuenn Roofing/Siding 2 06-25-2009 11:30 AM
Delta-FL "The Warm & Dry Floor Systm joedadog Flooring 4 04-11-2009 06:40 PM
My house is a project Part III "The basement" tigerbalm2424 Project Showcase 12 12-20-2008 11:53 AM
