Chris The DIY Guy Vs. "The Ranch" - Project Showcase - Page 24 - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 05:36 PM   #346
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Dropping soffit for shower rain panel was hard work for only 5 inches! Have the outside done will complete inside supports next.
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 03-09-2013, 04:35 PM   #347
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Rough work for all the shower heads and body sprays compete. Need to connect PEX into valvein basement.
Sent from my Samsung Galaxy Tab 2 using DIY Chatroom
--Chris the DIY Guy
Old 03-10-2013, 04:30 PM   #348
Still going...
ChrisDIY's Avatar
Rewards Points: 508
This is awful!!! One of the six unions Cello brand is stripped, I am not confident the other five will not leak. I now have to do a leak test BEFORE I do the flood test. Don't buy cheap Cello brand made in China.
--Chris the DIY Guy
Old 03-18-2013, 08:12 PM   #349
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Finished plumbing connections at the valve. Bought all new unions, Watts brand, better made but still from China.
--Chris the DIY Guy
Old 03-30-2013, 01:42 PM   #350
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Installed the Pre-Pitch, now the mud
--Chris the DIY Guy
Old 03-31-2013, 03:13 PM   #351
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Oh no! Will be renting a cement mixer for the shower pan, mixing in a box too much work
--Chris the DIY Guy
Old 03-31-2013, 07:55 PM   #352
Registered User
Rewards Points: 5,266
Keep it safe, don't forget the fire-blocking, #12; How to fireblock framing
Gary
Old 03-31-2013, 08:43 PM   #353
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Gary
I just put in a new wall within the existing. Does this mean it wasn't in the original wall?
--Chris the DIY Guy
Old 04-01-2013, 08:52 AM   #354
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I have been using this stuff for penetrations.
Fomo Fireblock
--Chris the DIY Guy
Old 04-04-2013, 12:09 AM   #355
Registered User
Anytime you lower the ceiling below the single/double top plate, you need additional fire-blocking in connecting walls to stop fire from getting above the new ceiling, unless the lid is drywalled. Read a few pages in that link. Also, pp. 5, here: http://www.codecheck.com/cc/ccimages...CB3_sample.pdf
Gary
Gary
Old 04-04-2013, 12:32 AM   #356
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Ok, got it thanks! Will use the unfaced insulation. Will help with the heat loss in the water lines leading to body sprays and shower head incidentally.
--Chris the DIY Guy
Old 04-04-2013, 09:31 AM   #357
Bill Kearney
Rewards Points: 1,174
Don't forget to put a little slope under the ceiling! You want the condensation to be able to slide off it instead of dripping.
wkearney99 is offline   Reply With Quote
Old 04-04-2013, 10:13 AM   #358
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I have as much slope as can be done the rain panel has to be level.
--Chris the DIY Guy
Old 04-29-2013, 02:12 PM   #359
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Wow, its been so long since I have made a post that I am on page 2. Putting in cement board is taking a lot longer than anticipated. I do have 4 body sprays shower head, two speakers, and the control to all be roughed in.
Insert photo
--Chris the DIY Guy
Old 05-15-2013, 10:27 PM   #360
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Finally to the quick pitch setup step. Well be doing the mud Saturday.
--Chris the DIY Guy
Chris the DIY guy! ChrisDIY Introductions 1 02-18-2010 11:19 PM
"the edge" edge vents k.kuenn Roofing/Siding 2 06-25-2009 11:30 AM
Delta-FL "The Warm & Dry Floor Systm joedadog Flooring 4 04-11-2009 06:40 PM
My house is a project Part III "The basement" tigerbalm2424 Project Showcase 12 12-20-2008 11:53 AM
