Chris The DIY Guy Vs. "The Ranch" - Project Showcase - Page 23 - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 08:15 PM   #331
Still going...
ChrisDIY's Avatar
Rewards Points: 508
We have slowly seen our hot water diminish. After some tinkering have determined that the thermostatic mixing valve is going bad. Our kitchen faucet normally would kick on tankless, but now it won't. Did experiment and turned cold off. Water will not get any hotter than 110 with the thermostatic mixing valve all the way up. Which is supposed to be 145. Will be ordering replacement. Both tankless units are producing their set temp of 150.
Sent from my Samsung Galaxy Tab 2 using DIY Chatroom
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 08-21-2012, 01:17 PM   #332
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I guess having this issue prompted reading some reviews so may have solution to another issue. Apparently, the mixing valve will only flow MAX 3.9 gpm per side. In order for the planned shower to work I will need to put in two mixing valves "in parallel" in order to get higher flow rate and also may alleviate the water hammer. Would not have know this without reading review from a buyer.
--Chris the DIY Guy
Old 09-05-2012, 08:41 PM   #333
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Turned the tankless temperature down from 150 to 120 and there is some improvement in flow. Flow rate was 0.7 gpm with lower temp went up to 1.1 gpm
--Chris the DIY Guy
Old 09-06-2012, 12:45 PM   #334
Whew! That seemed like a lot of work! Looking good, so far.
Fishinbo is offline   Reply With Quote
Old 09-06-2012, 02:20 PM   #335
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Yep, have to rehab/remodel whole house one room at a time!
--Chris the DIY Guy
Old 10-14-2012, 09:54 PM   #336
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Been a long time since my last post. Babies room is finished in time for our new arrival born October 3rd.
I feel bad... We have been having this ongoing problem with a hydrogen sulfide smell isolated to hall bathroom sink. I sanitized well and all plumbing numerous times to no avail. Then I made unfortunate discovery. I had forgotten that I filled water heaters with water back in 2009. Although valves were closed bacteria had produced enough gas to leak through ball valve. I spent all day Saturday taking out water heaters and associated plumbing. Valve at bottom of heater was broken so could not drain, so had fun moving 400 lbs. by myself.
--Chris the DIY Guy
Old 10-14-2012, 09:57 PM   #337
Still going...
ChrisDIY's Avatar
Rewards Points: 508
When I disconnected hot water hose on one heater a mucus like slime oozed out with a lot of gas. Then black water. Found the problem : sad:
I see they haven't fixed the photo in portrait posting issue...
--Chris
--Chris the DIY Guy
Old 10-17-2012, 07:14 AM   #338
REDRUM's Avatar
Originally Posted by ChrisDIY View Post
if you havent done this yet, you could have your shower glass guy drill 2 holes in the shower and back to back mirrors and use standoffs like
to mount the mirrors outside the shower....
cool idea by the way
REDRUM is offline   Reply With Quote
Old 10-17-2012, 08:25 PM   #339
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Decided on a plan a little later on. Running all new drain pipe was more than I am willing to do.
--Chris the DIY Guy
Old 10-17-2012, 09:39 PM   #340
JulieB's Avatar
I looked through each page of your thread. You are amazing.
JulieB is offline   Reply With Quote
Old 12-01-2012, 05:57 PM   #341
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Resuming work! Our daughter is now two months old so starting back up on master bath/closet/bedroom. Ceiling will need a complex framing due to vent and can lights.
--Chris the DIY Guy
Old 01-05-2013, 09:41 PM   #342
Still going...
ChrisDIY's Avatar
Rewards Points: 508
So who would have thought, those cheap filters are actually better than those "allergen" pleated filters.
Having trouble finding tile to match wife's "inspiration" room. That uses Thassos marble. I do wonder with Greece's economic problems, is it a risky proposition anyway. It's marble and not oil... Will probably post question in tile forum. I want to also make an edge in tile and not sure how to do it so it won't fail.
--Chris the DIY Guy
Old 01-27-2013, 09:54 PM   #343
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Been a while since I made an entry. We had some very cold days recently and it became apparent that an outage during cold months would leave the house too cold to do the manual second generator. Will start plan to install second ATS.
Shower design is turning out to be tougher that initially thought. Will need to make some sacrifices. Steam showers call for a pitch to ceiling but after drawing my lines out this is going to look weird. Since we will be using as shower 95% of the time and the walls of the soffit are vertical anyway there is no way to avoid cold drips. Somehow would have to make a lip to carry water away from the vertical soffit walls. Seems that would create point of grout failure.
--Chris the DIY Guy
Old 02-07-2013, 10:22 PM   #344
Still going...
ChrisDIY's Avatar
Rewards Points: 508
The two thermostatic valves have been taken out. The design of the Hydronic heat doesn't work well with a multi unit install with low flow and high flow requirements. No water hammer and all faucets now work fine. For the first time we actually have lukewarm water.
Attachment 65123
Just too many incompatible components. First being the WaterSense faucets. Second tankless pressure drop to maintain water temp. Lastly, bath design involving multiple simultaneous water fixtures.
--Chris the DIY Guy
Old 03-08-2013, 04:33 PM   #345
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Been working steady on master shower. First time using PEX. Much easier to use, should have been using it earlier.
--Chris the DIY Guy
Chris the DIY guy! ChrisDIY Introductions 1 02-18-2010 10:19 PM
"the edge" edge vents k.kuenn Roofing/Siding 2 06-25-2009 10:30 AM
Delta-FL "The Warm & Dry Floor Systm joedadog Flooring 4 04-11-2009 05:40 PM
My house is a project Part III "The basement" tigerbalm2424 Project Showcase 12 12-20-2008 10:53 AM
