Chris The DIY Guy Vs. "The Ranch" - Project Showcase - Page 22 - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 07:05 PM   #316
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Being pressed for time decided to use sprayer to paint molding. Boy this so much easier, except for bugs that suddenly decide to land on wet work. I painted five 8' base and eight 8' door casing in an hour including set up and clean up. I wish I had used it to paint table legs.
Will take some pictures Friday after I put them in place.
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 07-21-2012, 06:01 PM   #317
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Spent this past Wednesday getting generator set in place for electrician today.
Took most of this morning and afternoon for us to get the electrical all ran. Now the long wait for the propane company to come out.
--Chris the DIY Guy
Old 07-21-2012, 06:06 PM   #318
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Elected to run both electrical and propane "above" ground after thee septic drain line was hit in same area when propane was first put in. Thus the support.
Will need to place more gravel on the exhaust side of unit.
--Chris the DIY Guy
Old 07-25-2012, 11:33 PM   #319
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Can't seem to get an answer from propane company on the line, what material and does it have to be buried. I am just fearful they will hit the septic line again! I have a heavy pipe rod maybe line can be located that way?
--Chris the DIY Guy
Old 08-01-2012, 10:01 PM   #320
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Propane company came out today, everything they can do involves trenching so on to the black pipe. Will need to find the appropriate paint for it.
Also, worked on getting the downspouts drained under the retaining wall and future over sidewalk. Will post a picture of this tomorrow.
--Chris the DIY Guy
Old 08-02-2012, 09:54 AM   #321
Still going...
ChrisDIY's Avatar
Rewards Points: 508
As promised pictures of drain. I excavated enough to replace with topsoil to grade. I have one little hump too remove.
I dug a trench underneath the pipe and compacted #53 some here. May have been overkill, but don't want any issues.
The entire drain will be underground once I have upper retaining wall in place.
On to the propane and painting.
--Chris the DIY Guy
Old 08-03-2012, 03:22 PM   #322
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Resuming trench for retaining wall, very difficult since out had been so dry. Soaking then digging...
--Chris the DIY Guy
Old 08-04-2012, 01:12 PM   #323
Still going...
ChrisDIY's Avatar
Rewards Points: 508
After three more hours today finished trench, now to find the end of my drain.
--Chris the DIY Guy
Old 08-04-2012, 03:21 PM   #324
shadytrake's Avatar
Rewards Points: 364
Looking good.
shadytrake is offline   Reply With Quote
Old 08-05-2012, 03:39 PM   #325
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Final excavation!
--Chris the DIY Guy
Old 08-08-2012, 10:31 PM   #326
Still going...
ChrisDIY's Avatar
Rewards Points: 508
This gas line is giving me the flux. I keep forgetting the Golden Rule. Do plumbing BEFORE electrical.
Ordered more block today so I can resume with the wall next week.
--Chris the DIY Guy
Old 08-12-2012, 03:42 PM   #327
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Generator installation complete! Just a few minor things like painting the gas line and gravel at exhaust end, to do.
Attachment 55670
--Chris the DIY Guy
Old 08-13-2012, 07:34 PM   #328
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I should have known... Painting the babies room I thought would be easy. Why is the carpet all the way under the drywall?
--Chris the DIY Guy
Old 08-13-2012, 11:27 PM   #329
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Those blocks sure look nice. I like the way they lock together. What do they cost each? I'm doing a wall right now too. Keep up the great work. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 08-14-2012, 08:01 AM   #330
Still going...
ChrisDIY's Avatar
Rewards Points: 508
They are called Allan Block AB Classic. Roughly $7 each weighs 75 lbs each.
--Chris the DIY Guy
Chris the DIY guy! ChrisDIY Introductions 1 02-18-2010 10:19 PM
"the edge" edge vents k.kuenn Roofing/Siding 2 06-25-2009 10:30 AM
Delta-FL "The Warm & Dry Floor Systm joedadog Flooring 4 04-11-2009 05:40 PM
My house is a project Part III "The basement" tigerbalm2424 Project Showcase 12 12-20-2008 10:53 AM
