Chris The DIY Guy Vs. "The Ranch" - Project Showcase - Page 20 - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 09:44 AM   #286
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Originally Posted by shumakerscott View Post
What about an infrared heat light? dorf dude...
I plan on putting a dual lamp outside shower. To me it was cool "in" the shower. When you stepped out of the water stream. Seems like steam unit would always have to be on? Well maybe with a steam shower door it may warm up compared to standard door?
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 03-04-2012, 10:34 PM   #287
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Now that Spring is around the corner it's time to list projects for this year.
1. Finish retaining wall
2. Build support for heat pump that is attached to the house (see #3)
3. Increase water pipe size through foundation wall, fixing leak in process. Pipe entrance is under current support for heat pump. Driest period of year late July.
4. Over seed lawn
5. Till under fence row and plant wildflower seeds.
6. Install automatic transfer switch
7. Install manual transfer switch and outdoor connection. Second generator is "way" down the line...
8. Buck all the downed trees (June)
9. Rough plumbing work for master bath, close up walls
That's at least 9+ Wednesdays accounted for!
Sent using Android DIY Chatroom
--Chris the DIY Guy
Old 04-07-2012, 11:06 PM   #288
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Up to the 6th and final course on retaining wall. Will finish most of the backfill tomorrow. Will top off with soil that will be trucked in this week.
Picture at 5th course complete.
Application of "Geo-Grid" before sixth course
Will need to rent a brick saw to cut top caps along with topsoil placement.
--Chris the DIY Guy
Old 04-28-2012, 03:44 PM   #289
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Been a while since I worked indoors. Spent today removing some "boxed-in" plumbing that was done previously. See post #142 for reference as to how it looked.
Chris the DIY guy vs. "The Ranch"-cut-clean.jpg   Chris the DIY guy vs. "The Ranch"-inside-cut.jpg   Chris the DIY guy vs. "The Ranch"-1st-glue.jpg
--Chris the DIY Guy
Old 04-28-2012, 03:47 PM   #290
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I decided not to remove all the insulation in the attic and bring the portion in our pantry above the ceiling. So we are stuck with the vent pipe there. Next I have to remove the 15A circuit and reroute it.
Chris the DIY guy vs. "The Ranch"-inside-glue.jpg   Chris the DIY guy vs. "The Ranch"-15a-box.jpg
--Chris the DIY Guy
Old 05-05-2012, 10:14 PM   #291
Still going...
ChrisDIY's Avatar
Rewards Points: 508
We had the transfer switch installed today! One more step to go! This will require some thought. Given the fact that the sewer line was hit by the propane installers with a trencher I am trying to keep all the lines above ground. I am thinking there isn't a reason power inside conduit cannot be above ground as well as solid gas line (iron).
--Chris the DIY Guy
Old 05-24-2012, 10:59 PM   #292
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Began fabrication of dining table, have to rip top in two directions. Completed test cut for one of the short cuts, will do both end cuts tomorrow.
Feeling a little uneasy about the long rip...
Finished caps on retaining wall, ready to order soil.
--Chris the DIY Guy
Old 05-25-2012, 07:11 PM   #293
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Three rips completed successfully!
--Chris the DIY Guy
Old 06-01-2012, 09:20 PM   #294
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Working on apron and legs. Top is turned over covered in plastic
and is working as temporary work surface.
--Chris the DIY Guy
Old 06-01-2012, 10:49 PM   #295
Work Hard, Play Harder
Rewards Points: 212
Pics of finished retaining wall? It looked really good in progress.
coderguy is offline   Reply With Quote
Old 06-02-2012, 02:37 PM   #296
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I keep having issues uploading from phone. Will close in after soil is placed (on right). Once I have the other side done will place #53 stone and complete paver walkway down to door.
--Chris the DIY Guy
Old 06-02-2012, 09:33 PM   #297
Rewards Points: 212
That looks really clean, I look forward to seeing it completely finished.
Old 06-05-2012, 12:21 PM   #298
Still going...
ChrisDIY's Avatar
Rewards Points: 508
The mound of soil in front and to the right has to be removed, probably tomorrow so to be pitched away for drainage.
--Chris the DIY Guy
Old 06-05-2012, 12:26 PM   #299
Still going...
ChrisDIY's Avatar
Rewards Points: 508
End assemblies complete the more difficult task of attaching to long aprons tonight. I don't have clamps this long so will be trying the ones that use black iron pipe...
--Chris the DIY Guy
Old 06-06-2012, 01:31 PM   #300
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Use of pipe clamps turned out to be difficult (heavy) so needed some help from wife
--Chris the DIY Guy
Chris the DIY guy! ChrisDIY Introductions 1 02-18-2010 11:19 PM
"the edge" edge vents k.kuenn Roofing/Siding 2 06-25-2009 11:30 AM
Delta-FL "The Warm & Dry Floor Systm joedadog Flooring 4 04-11-2009 06:40 PM
My house is a project Part III "The basement" tigerbalm2424 Project Showcase 12 12-20-2008 11:53 AM
