10-10-2011, 03:34 PM
#256
Still going...
Chris the DIY guy vs. "The Ranch"
Originally Posted by cocobolo
Jim, what we routinely do is to make an enclosure where the batteries are...
I will put up a pic of the process on my thread as it proceeds.
If I used the online calculator correctly to do a 1:1 switch from generator to battery I would need 3,160 Ah? At 48V I am not sure how many batteries that would be since you have to figure on series and parallel portions. I would need to create a spreadsheet. but from rough calculations a generator is cheaper. Seems like a better idea would be to have a bank that would work for a few hours.
How ironic, as I was beginning to think about building an un-interruptible power supply to go along with the generator. Switching mechanism do they exist?
--Chris the DIY Guy
Still going, on Ibuprofen...
10-10-2011, 03:47 PM
#257
3,160 amp hours? What would that run and for how long. That is huge consumption. Would that by any chance be watt hours?
Just an old guy messin' with bits of wood...
...the friendliest thread on the site! Come on by. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-14-2011, 01:26 AM
#258
Sorry...I didn't spot this question before.
Yes, fully automatic switching and starting systems are available.
I suggest you visit the Homepower website, there is everything you would ever want to know about the subject. I think it's www.homepower.com
10-17-2011, 01:07 PM
#259
Still going...
Started excavation for retaining wall. Having trouble getting posts out of ground, tractor break out force seems not to be strong enough? Unless I am doing it wrong?
Sent from my Samsung Vibrant using Android DIY Chatroom
--Chris the DIY Guy
10-17-2011, 01:26 PM
#260
Dorf dude...
Chris, I'm having trouble following your project. Not enough pic's with descriptions. It went from bathroom to digging outside. What was in this location before? Need a little more information to see the complete picture. Thanks, dorf dude...
Today is only yesterdays tomorrow, Now get to work!
10-17-2011, 01:59 PM
#261
Still going...
Before pictures, see also pictures in very first post. I am basically doing the entire house over, by myself. Used a chain connected to my loader. Tried to pull up vertically, the first two posts snapped off at the ground. I do not see any cement. Originally owner put up this post and OSB retaining wall which finally fell over so far had to interrupt my interior projects to address. Final block wall will turn and meet vertical portion of front porch.
--Chris the DIY Guy
10-17-2011, 02:07 PM
#262
Dorf dude...
That is Ugly!  I know I don't need to say it but waterproof and add drainage. More pic's is always better  dorf dude
10-17-2011, 04:42 PM
#263
STAFF
If you still have a post that is hard to pull up try this: Take a chain and hook as close to the bottom of post as possible, us an old car tire standing against the post with the chain laying over the tire, when you pull the chain it should pull the post up out of the ground.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
10-17-2011, 10:05 PM
#264
The old guys always have the answers, don't they Jim!
10-18-2011, 08:52 AM
#265
Coconut Pete's paella!
WOW! "OSB Retaining wall" - seems like an oxymoron doesn't it.
10-18-2011, 09:26 AM
#266
Hmm. Now I'm thinking that 'paving' my driveway, patio and walkway with OSB isn't going to be such a good idea.
"The problem with quotes on the Internet is that it is often difficult to verify their authenticity." - Abraham Lincoln
The economy is so bad, Exxon-Mobil laid-off 25 congressmen --- Maxine
10-18-2011, 10:47 AM
#267
Still going...
Wow! Thanks! Will get a hold of an old tire and try this. Raining now so will need to wait till things dry out.
--Chris the DIY Guy
The Following User Says Thank You to ChrisDIY For This Useful Post:
10-18-2011, 06:25 PM
#268
STAFF
I forgot to say the tire needs to be on the rim, flat or not it should work. Just don't back up and make a running jerk, there is no telling where that post may go.
I saw a young guy pull a pine tree out of the ground with a running jerk using a nylon rope and the tree turned into a rocket after it tore up his tail gate and top of his cab. He wasn't using a tire but a straight jerk, but the post could go airborne with a running jerk.
Jim
10-20-2011, 09:39 AM
#269
Still going...
Still raining and wet, given that I have a 12 post deck that could have easily been done with 4, these posts could be as deep as 4-8 feet in the ground. Given lumber comes in 10', 12' and 14' About 6' is sticking out of the ground.  I need to check strength of my chain. I am going to need a pretty substantial size diameter tire.
--Chris the DIY Guy
10-23-2011, 01:10 PM
#270
Still going...
Still a bit damp and some muddy spots, but had to get going. Doing things the old fashioned way. Dug down about 1.5 feet, wrapped chain and it pulled out. First post was just stick in ground about 4 feet. Second post is set in concrete. We will see how this one goes.
--Chris the DIY Guy
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
