#211 |
Chris the DIY guy vs. "The Ranch"
Looks good! I can't wait to see it finished.
#212 |
Work Hard, Play Harder
That tile looks great; This thread is very helpful as I start to plan our bathrooms. Can't wait to see you finish it up!
#213 |
Still going...
Finished the hydro-barrier so will be tiling the floor tomorrow. Since the shower base is the line of sight I will use that for reference.
Sent from my Samsung Vibrant using Android DIY Chatroom
--Chris the DIY Guy Still going, on Ibuprofen... |
#214 |
Still going...
Houston....
We have marble..... The floor is in although there were some cracked tiles in the boxes, had four extra. Will keep in basement "just in case." Sent from my Samsung Vibrant using Android DIY Chatroom
#215 |
#216 |
Still going...
#217 |
Floor, lol.
#218 | |
Chris the DIY guy vs. "The Ranch"Quote:
If the paint is well cured, and you press the tape just on the side you are trying to protect it usually works OK. One of the biggest secrets is removing the tape as soon as possible after you have applied it.
Just an old guy messin' with bits of wood... ...the friendliest thread on the site! Come on by. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#219 |
Chris...are you saying that you put marble tile on the floor?
#220 |
Still going...
Yes, just the Lowe's variety, nothing fancy. Will post a picture tonight. I didn't take a picture of the underlayment and membrane application.
#221 |
Still going...
Photos of "the floor."
#222 |
Still going...
Closet flange cut out.
#223 |
Still going...
No lippage...
#224 |
Still going...
Overall, will be working on the base cove tile tonight.
#225 | |
The reason I asked if you were using marble on the floor was only due to the safety factor. I don't know if you have ever tried to walk on wet marble, but it's extremely slippery. Perhaps there is some sort of sealer you can add to try and alleviate some of the slickness, I really don't know. Get hold of Bud Cline on the site here and see if he has any suggestions. I did a job for a customer once and she insisted on marble tile on a step getting out of a fancy soaker type tub. Nothing I said was going to convince here to use anything else. Finally I said if I put marble on that step (the tub was set in a marble surround) I'm going to get you to sign a piece of paper guaranteeing me that you will use a foam backed piece of carpet on that step when you use the tub. She signed, I installed, and even then it was against my better judgment.
| Display Modes | |
| Chris the DIY guy! | ChrisDIY | Introductions | 1 | 02-18-2010 11:19 PM |
| "the edge" edge vents | k.kuenn | Roofing/Siding | 2 | 06-25-2009 11:30 AM |
| Delta-FL "The Warm & Dry Floor Systm | joedadog | Flooring | 4 | 04-11-2009 06:40 PM |
| My house is a project Part III "The basement" | tigerbalm2424 | Project Showcase | 12 | 12-20-2008 11:53 AM |
