-   Project Showcase (http://www.diychatroom.com/f49/)
-   -   Casper129's Basement Finishing Project Thread... (http://www.diychatroom.com/f49/casper129s-basement-finishing-project-thread-111681/)
casper129 07-23-2011 02:12 AM
So today I started working on our basement.. The wife and I are hoping to have it completed before the baby comes in Jan. of 2012.. (Very Ambitious..) I figured I would start this thread for you guys to comment on my progress, and any suggestions will be welcome, and taken into consideration.. I'll start out with here is what I did today:
Took out part of the wall to open up the stairway..
http://i22.photobucket.com/albums/b3...l/IMG_1193.jpg
Put up 2" XPS and I am building the wall out of 2x6 top plate and 2x4 PT bottom plate with Poly Sill Seal under it, with regular 2x4 studs.
http://i22.photobucket.com/albums/b3...l/IMG_1198.jpg
What my plans are for fireblocking:
With the top plate being a 2x6...
http://i22.photobucket.com/albums/b3...l/IMG_1200.jpg
I have it almost against the cement foundation..
http://i22.photobucket.com/albums/b3...l/IMG_1202.jpg
I left this small gap between the 2x6 and the XPS, in which I will spray Great Stuff Fireblocking Foam..
http://i22.photobucket.com/albums/b3...l/IMG_1201.jpg
Is that an acceptable method? Thoughts? Comments? I also thought I would mention, we plan on putting in a drop ceiling.. so would I have to actually have fireblocking lower, where the drop ceiling starts?
I know I have to fireblock every 10 feet side to side, so I figure at the end of that 10 foot chunk of wall, I will cut a 1" slice out of the XPS and put in a sheet of drywall thick enough to go to the cement, and foam it with the great stuff fireblock spray.. Again, acceptable?
This is my first time doing anything like this, but I am fairly capable at it (I think) The basement will be completely rewired, so try not to pay attention to the wires :) I will try to keep this thread current, as I am always looking for insight from people more professional at it than myself. Thanks!
joetab24 07-23-2011 11:58 AM
are permits required?
casper129 07-23-2011 12:13 PM
Yes, they are required with any kind of remodel/renovation like this. Whether the homeowner decides to get a permit or not, is out of my control. I personally will not be pulling permits.. but I do want everything (mostly) to be up to code.. especially the fire-blocking, for safety's sake.
casper129 07-24-2011 08:23 PM
Do I have this in the wrong place for asking questions? Over 1,000 views, and only 1 other person made a comment? I thought I could get a lot of help here, but I can't wait three days to figure out what to do with my predicament.. :)
gma2rjc 07-24-2011 10:14 PM
??? In the first post you mentioned that this is your house. Anyway, keep posting progress pictures. You're off to a good start!
casper129 07-25-2011 12:14 AM
Yes, this is my house.. but I had a hard time figuring out why someone would really ask if permits were required, when it's fairly common knowledge that almost ANY kind of remodeling on a house requires a permit... Then I said "Whether the homeowner (namely Joetab [since he asked about it]) decides to get a permit or not..." But I will personally not be pulling a permit.
I have a question about sealing the bottom of the 2" XPS - Would a regular silicone caulking work.. and how do you guys get the XPS to stick to the wall well? I can move one of my sheets after two days of letting the glue dry. I used PL300 and it's almost like it's wet yet... (Basement is completely dry, with a dehumid. running at 45% rel) ...
CoconutPete 07-25-2011 11:03 AM
Generally people post pictures and stories in here in the "Project Showcase".
If you want to do Q&A it's probably better to post in one of the other forums - maybe "remodelling"?
casper129 07-25-2011 11:10 AM
^ Alright, thanks for pointing me in that direction :)
Termite 07-26-2011 12:02 PM
In response to the inquiry you sent, I think your fireblocking plan is spot-on. :yes:
Your plan to not get a permit and have your work double checked by a professional...Not so spot-on. :no:
casper129 07-26-2011 01:11 PM
Termite - I'm only choosing not to get a permit because we do have professionals in the family. The building part I'm not to worried about, as I think I can work my way though it with the help of this website :) The electrical, I'm fairly confident about.. but I will have it double checked by a state licensed electrician, which is my wife's uncle.
casper129 07-28-2011 05:32 PM
Brought some more stuff home today so I can keep working on my basement :)
http://i22.photobucket.com/albums/b3...l/IMG_1208.jpg
casper129 07-30-2011 10:02 PM
Where I am today...
More Progress...
http://i22.photobucket.com/albums/b3...l/IMG_1214.jpg
http://i22.photobucket.com/albums/b3...l/IMG_1215.jpg
http://i22.photobucket.com/albums/b3...l/IMG_1217.jpg
http://i22.photobucket.com/albums/b3...l/IMG_1218.jpg
http://i22.photobucket.com/albums/b3...l/IMG_1237.jpg
http://i22.photobucket.com/albums/b3...l/IMG_1234.jpg
http://i22.photobucket.com/albums/b3...l/IMG_1238.jpg
http://i22.photobucket.com/albums/b3...l/IMG_1243.jpg
quiksheit 07-31-2011 02:38 PM
Nice. Can you explain a little more about what you are using for the floor. Maybe Im not keeping up with all new products out there
casper129 07-31-2011 03:20 PM
The flooring is a product called "Platon" that they sell at Menards. It's the same product (basically) as Delta-FL that they would sell at Lowes. It's basically a cheaper alternative to Dri Core. I laid down landscaping fabric first, that way in case my floor is off level by a little bit, the plastic of the Platon won't make an audible "click" when walking on the flooring. I have only read about other people's floors having this issue, so I only did it to prevent any future problems. Then once I get all of the Platon laid down, I seal it to my bottom plate with Great Stuff, and then lay my 3/4" T&G Subfloor down on it. I am placing 8 tapcon screws on each 4x8 sheet of subfloor to hold is all in place.
gma2rjc 10-14-2011 06:24 PM
Any new updates?
