Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 01-27-2013, 08:25 PM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Bungalow- Two New Stories From Design To Build
Originally Posted by cocobolo View Post
Never mind the house for a minute...we'll get back to that later.
Fill me in on the hotrod!!!
The hot rod is a 1941 Chrysler New Yorker two door coupe.
All stainless steel chassis with an 04 Cobra IRS. Power will be a 496 BBC with with sequential fuel injection. Transmission will be a 4 speed automatic with overdrive. Coupled to that will be a GearVendors overdrive unit for double overdrive. So 600 FT/LBS of torque and hopefully 20 MPG to boot.
Oh yeah, and the car should even look cool as the whole front snout has been cut off and fitted with a custom shaped clip using 37 Ford headlights.
About 5 years still left on the rod and about two years coming up on the house so should be ready by 2020. Maybe.
Check it out:
http://ontariorodders.activeboard.co...41-new-yorker/
123pugsy is offline   Reply With Quote
Old 01-27-2013, 09:07 PM   #17
cocobolo's Avatar
Man oh man...I tried to find fault with your work...but there just isn't anything even remotely there a guy can find to criticize. What a spectacular frame!
Ahhh...but you need to spell of coArse..of coUrse. Jeez, you'd think a Chevy guy would know that!!!
Now, about this house of yours. Put it on the back burner and waste your days and nights away on that incredible machine until it's done!
That thing is just WAAAAAY to cool!
Just an old guy messin' with bits of wood...
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 01-27-2013, 10:35 PM   #18
STAFF
BigJim's Avatar
Check it out:
Oh my stars, WOW with a capital WO, that is one fine machine!!! Buddy if you build your home anywhere as good as you have done on your rod it is going to be spectacular. I will be following your build, man oh man.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 01-28-2013, 05:43 AM   #19
123pugsy's Avatar
Thanks cocobolo.
Unfortunately, the house has been on the back burner since I got the car. Its time to take care of this "Hainey Place" once and for all. I got to get the house done so when its time to retire it'll be good enough to live in or good enough to sell.
Old 01-28-2013, 05:46 AM   #20
123pugsy's Avatar
Thanks Jim.
I'll be getting the calipers out when the house goes up so I hope the quality will be as good as the rod.
The Following User Says Thank You to 123pugsy For This Useful Post:
BigJim (01-28-2013)
Film / Photo Studio Interior Design BryanRoberts Interior Decorating 5 11-30-2011 06:31 PM
How To Check A Steel Carport Design abrogard Building & Construction 8 10-05-2010 04:59 AM
General HVAC Design Issue Robert Green HVAC 4 05-29-2010 12:02 PM
To Build or Not To Build scoby1978 General Discussion 6 05-27-2007 05:39 PM
