Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 11-27-2011, 10:54 AM   #1
old guy contractor
tcleve4911's Avatar
Building my shed Part 1
As we approach winter, I really need to get some stuff picked up, sorted and under cover (besides frikkin' blue tarps!!!!)
But how do you decide what to build and where it's going to live without being an eyesore.
So the first task was to choose the spot.
I start with a cornerstone and run everything off that point
...and lay it out with some blocks and tape so I could visualize it.
I decided 12' x 16' would be a decent start
Cut down a few saplings that were in the way and made a seat to take a break on.....
Pulled the stumps
The inspector showed up just in time and gave her input and approval.
...so I set up my high-tech transit
and set my outside rims
When I was happy with those, I finished the perimeter
That's all for today.....I'll be back in the morning
tcleve4911 is offline   Reply With Quote
Old 11-27-2011, 11:09 AM   #2
old guy contractor
tcleve4911's Avatar
So today I'm going to run all the joists and sheath the deck
When I'm working alone and need to set the joists, I clamp a cleat on the other end to hold the joist temporarily in place.
I decided to run my framing at 19.314579 " on center
All the joists in and secured
Ran the 3/4" T&G sheathing...and screwed her down
It went good and we now have a platform to work from
So while I was uncovering scraps from under the tarps, I decided to make me some steps
That's enough for today
The Following 2 Users Say Thank You to tcleve4911 For This Useful Post:
Edgar214 (12-30-2011), shumakerscott (11-28-2011)
Old 11-27-2011, 09:52 PM   #3
great illustrations. So, you are allowed to just sit the concrete piers on dirt like that? I was under the impression they had to sit on a more solid surface, like sonotube filled with concrete and rock.
SeeDBee is offline   Reply With Quote
Old 11-27-2011, 11:17 PM   #4
Super Moderator
He's got a 'thing' going with the inspector.
Old 11-28-2011, 09:00 AM   #5
Coconut Pete's paella!
CoconutPete's Avatar
Nice!
CoconutPete is offline   Reply With Quote
Old 11-28-2011, 10:19 AM   #6
Looking good! Looks like ma nature is tolerant of you waiting until this late in the year, and is giving you some great late-season weather to work in!
Old 12-04-2011, 10:28 AM   #7
old guy contractor
tcleve4911's Avatar
Undisturbed soil is your friend........
Old 12-04-2011, 10:29 AM   #8
old guy contractor
tcleve4911's Avatar
What??...I pay my fees.....
The Following User Says Thank You to tcleve4911 For This Useful Post:
oh'mike (12-04-2011)
Old 12-04-2011, 01:52 PM   #9
A "Handy Husband"
rjniles's Avatar
Questions:
No joist hangers? Floor joists nailed to the rims?
Rims nailed to posts? No additional support.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-04-2011, 02:25 PM   #10
old guy contractor
tcleve4911's Avatar
So with the platform built, it's time to frame some walls.
I'll use 2x4x8' with shoe and double top plate to give 100-1/2" ceiling height.
....plus I don't have to cut any of them
So it's off to the lumber yard
I built my walls on the deck and raised them in manageable sections (8')..
and braced them plumb and square with clamps and a GRK screw.
Things went really fast at this point and before I knew it, I had all the walls up but no progress pics.
So I braced everything off so I could start my sheathing
Old 12-04-2011, 02:26 PM   #11
old guy contractor
tcleve4911's Avatar
So off to the lumber yard to get some boards.
Boards???? no plywood??...osb??? ...waferboard???...particle board??????
Nope......Boards...... good old fashioned 1x12 D3S...7/8" x 12" nominal.
A new business came to town and was offering 1x12 at 30¢/lf !!!!
...and I got a new hat!!!!!
So I started out by running a 3" horizontal strip to set the diagonal sheathing on top of.
This gave me a straight and level course to work off and protected the end-grain of the cuts.
I decided to stop sheathing at this point because I want to have the roof rafters on and the gables framed so I can tie in the sheathing to the gable ends.
So I'm off to the Lumber Yard again to get my 2x6x10' rafters and ceiling joists.
I ran the ceiling joists so I can tie the two wall together before I set my rafters
[IMG]http://i172.photobucket.com/albums/w17/006546713/Shed/*****entheroof002.jpg[/IMG]
I used a couple of clamps to pull the walls in straight before I fasten the ceiling joists
entheroof001.jpg[/IMG]
I lay out my gable wall on the floor
and I make a template....
So while I'm cutting my rafters, I have to keep picking my saw up and putting down somewhere.....
Then I remembered an old trick...
Drive a nail or screw into the end of your sawhorse and leave about 3/4" sticking out.
[IMG]http://i172.photobucket.com/albums/w17/006546713/Shed/*****entheroof004.jpg[/IMG]
Now you have a place to hang your saw within easy reach and your not setting it on the wet ground or on top of the lumber you're constantly moving around....
[IMG]http://i172.photobucket.com/albums/w17/006546713/Shed/*****entheroof005.jpg[/IMG]
I get all the rafters cut and staged in place for installation.
I'm gonna get busy again without the ability to take pics
So I got 1/2 of the ridge pole up and a few rafters on.....
I'm done for today.........
Think I'll take a break on my benchseat
and enjoy the end of the day........
Old 12-04-2011, 02:45 PM   #12
old guy contractor
tcleve4911's Avatar
Old 12-04-2011, 02:53 PM   #13
old guy contractor
tcleve4911's Avatar
So while I'm cutting my rafters, I have to keep picking my saw up and putting it down somewhere.....
Old 12-04-2011, 03:02 PM   #14
old guy contractor
tcleve4911's Avatar
Originally Posted by rjniles View Post
Questions:
yep............old school....it's a shed........
...there are no nails connecting the floor joists to the rim.
They are all 6" structural GRK's
.....it's interesting nobody has picked up on the joist spacing at 19.314579" o.c.
Old 12-04-2011, 03:40 PM   #15
Are those just 2 X 6 floor joist?
No center supports, just outside piers, no hangers, rim joist attached to the outsides of the 4 X 4's not notched out and through bolted.
You lost at least 2 days by using those boards instead of reguler sheathing, way to many windows you lost all the wall storage space, 2 X 4 headers, using those pier blocks instead of setting 6 X 6's in concrete, floor joist not spaced at 16" on center. Why the odd ball joist spacing? Is this a metric lumber shed?
Sorry not impressed.
Shed building on Concrete pillars rfcready Building & Construction 8 05-14-2011 09:36 PM
building a storage shed blk90s13 Landscaping & Lawn Care 17 03-22-2011 11:42 PM
Building a 12x10' shed roofed outbuilding - questions dwoloz Roofing/Siding 3 10-02-2010 08:16 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
building a shed SirVisioneer Building & Construction 1 01-27-2009 08:25 PM
