-   Project Showcase (http://www.diychatroom.com/f49/)
-   -   Building my shed Part 1 (http://www.diychatroom.com/f49/building-my-shed-part-1-a-124722/)
tcleve4911 11-27-2011 09:54 AM
As we approach winter, I really need to get some stuff picked up, sorted and under cover (besides frikkin' blue tarps!!!!)
http://i172.photobucket.com/albums/w...ed/themess.jpg
But how do you decide what to build and where it's going to live without being an eyesore.
So the first task was to choose the spot.
http://i172.photobucket.com/albums/w...ndation004.jpg
I start with a cornerstone and run everything off that point
http://i172.photobucket.com/albums/w...ornerstone.jpg
...and lay it out with some blocks and tape so I could visualize it.
I decided 12' x 16' would be a decent start
http://i172.photobucket.com/albums/w...ndation002.jpg
Cut down a few saplings that were in the way and made a seat to take a break on.....
http://i172.photobucket.com/albums/w...eathing002.jpg
Pulled the stumps
http://i172.photobucket.com/albums/w...ndows001-1.jpg
The inspector showed up just in time and gave her input and approval.
http://i172.photobucket.com/albums/w...eeringfirm.jpg
...so I set up my high-tech transit
http://i172.photobucket.com/albums/w...dwithlaser.jpg
and set my outside rims
http://i172.photobucket.com/albums/w...ndation013.jpg
When I was happy with those, I finished the perimeter
http://i172.photobucket.com/albums/w...rimeterrim.jpg
That's all for today.....I'll be back in the morning
tcleve4911 11-27-2011 10:09 AM
Part 2
So today I'm going to run all the joists and sheath the deck
When I'm working alone and need to set the joists, I clamp a cleat on the other end to hold the joist temporarily in place.
http://i172.photobucket.com/albums/w...ndation015.jpg
I decided to run my framing at 19.314579 " on center
http://i172.photobucket.com/albums/w.../Shed/19oc.jpg
All the joists in and secured
http://i172.photobucket.com/albums/w...oorframing.jpg
Ran the 3/4" T&G sheathing...and screwed her down
http://i172.photobucket.com/albums/w...inchscrews.jpg
It went good and we now have a platform to work from
http://i172.photobucket.com/albums/w...Shed/floor.jpg
So while I was uncovering scraps from under the tarps, I decided to make me some steps
http://i172.photobucket.com/albums/w...tairmockup.jpg
That's enough for today
SeeDBee 11-27-2011 08:52 PM
great illustrations. So, you are allowed to just sit the concrete piers on dirt like that? I was under the impression they had to sit on a more solid surface, like sonotube filled with concrete and rock.
oh'mike 11-27-2011 10:17 PM
He's got a 'thing' going with the inspector.:laughing:
CoconutPete 11-28-2011 08:00 AM
Nice! :thumbsup:
DexterII 11-28-2011 09:19 AM
Looking good! Looks like ma nature is tolerant of you waiting until this late in the year, and is giving you some great late-season weather to work in!
tcleve4911 12-04-2011 09:28 AM
Undisturbed soil is your friend........
tcleve4911 12-04-2011 09:29 AM
What??...I pay my fees.....:thumbup:
rjniles 12-04-2011 12:52 PM
Questions:
No joist hangers? Floor joists nailed to the rims?
Rims nailed to posts? No additional support.
tcleve4911 12-04-2011 01:25 PM
So with the platform built, it's time to frame some walls.
I'll use 2x4x8' with shoe and double top plate to give 100-1/2" ceiling height.
....plus I don't have to cut any of them:no:
So it's off to the lumber yard
http://i172.photobucket.com/albums/w...ndation006.jpg
http://i172.photobucket.com/albums/w...hewalls003.jpg
I built my walls on the deck and raised them in manageable sections (8')..
and braced them plumb and square with clamps and a GRK screw.
http://i172.photobucket.com/albums/w...ndsteps003.jpg
http://i172.photobucket.com/albums/w...ndsteps004.jpg
Things went really fast at this point and before I knew it, I had all the walls up but no progress pics.
http://i172.photobucket.com/albums/w...hewalls005.jpg
So I braced everything off so I could start my sheathing
http://i172.photobucket.com/albums/w...ndsteps002.jpg
tcleve4911 12-04-2011 01:26 PM
Sheathing
So off to the lumber yard to get some boards.
http://i172.photobucket.com/albums/w...ndsteps005.jpg
Boards???? no plywood??...osb??? ...waferboard???...particle board??????
Nope......Boards...... good old fashioned 1x12 D3S...7/8" x 12" nominal.
A new business came to town and was offering 1x12 at 30/lf !!!!
http://i172.photobucket.com/albums/w...3/Shed/hat.jpg
...and I got a new hat!!!!!
So I started out by running a 3" horizontal strip to set the diagonal sheathing on top of.
This gave me a straight and level course to work off and protected the end-grain of the cuts.
http://i172.photobucket.com/albums/w...eathing003.jpg
http://i172.photobucket.com/albums/w...eathing004.jpg
http://i172.photobucket.com/albums/w...eathing001.jpg
I decided to stop sheathing at this point because I want to have the roof rafters on and the gables framed so I can tie in the sheathing to the gable ends.
So I'm off to the Lumber Yard again to get my 2x6x10' rafters and ceiling joists.
http://t3.gstatic.com/images?q=tbn:A...9KzTpjfawvyy9w
I ran the ceiling joists so I can tie the two wall together before I set my rafters
[IMG]http://i172.photobucket.com/albums/w17/006546713/Shed/*****entheroof002.jpg[/IMG]
I used a couple of clamps to pull the walls in straight before I fasten the ceiling joists
entheroof001.jpg[/IMG]
I lay out my gable wall on the floor
and I make a template....
http://t0.gstatic.com/images?q=tbn:A...MyqJA_WK8SCrwg
So while I'm cutting my rafters, I have to keep picking my saw up and putting down somewhere.....
Then I remembered an old trick...
Drive a nail or screw into the end of your sawhorse and leave about 3/4" sticking out.
[IMG]http://i172.photobucket.com/albums/w17/006546713/Shed/*****entheroof004.jpg[/IMG]
Now you have a place to hang your saw within easy reach and your not setting it on the wet ground or on top of the lumber you're constantly moving around....
[IMG]http://i172.photobucket.com/albums/w17/006546713/Shed/*****entheroof005.jpg[/IMG]
I get all the rafters cut and staged in place for installation.
http://i172.photobucket.com/albums/w...rafters001.jpg
I'm gonna get busy again without the ability to take pics
So I got 1/2 of the ridge pole up and a few rafters on.....
http://i172.photobucket.com/albums/w...rafters003.jpg
I'm done for today.........
Think I'll take a break on my benchseat
and enjoy the end of the day........
tcleve4911 12-04-2011 01:45 PM
Sheathing
http://i172.photobucket.com/albums/w...ndsteps002.jpg...and I got a new hat!!!!!
tcleve4911 12-04-2011 01:53 PM
Roof framing
http://i172.photobucket.com/albums/w...lingjoists.jpg
http://i172.photobucket.com/albums/w...ilingjoist.jpg
So while I'm cutting my rafters, I have to keep picking my saw up and putting it down somewhere.....
http://i172.photobucket.com/albums/w...sawhorse-1.jpg
http://i172.photobucket.com/albums/w...ngthesaw-1.jpg
http://i172.photobucket.com/albums/w...ofhalfdone.jpg
tcleve4911 12-04-2011 02:02 PM
Originally Posted by rjniles (Post 785800)
Questions:
yep............old school....it's a shed........
...there are no nails connecting the floor joists to the rim.
They are all 6" structural GRK's
http://i172.photobucket.com/albums/w...mbledracks.jpg
.....it's interesting nobody has picked up on the joist spacing at 19.314579" o.c.
joecaption 12-04-2011 02:40 PM
Are those just 2 X 6 floor joist?
No center supports, just outside piers, no hangers, rim joist attached to the outsides of the 4 X 4's not notched out and through bolted.
You lost at least 2 days by using those boards instead of reguler sheathing, way to many windows you lost all the wall storage space, 2 X 4 headers, using those pier blocks instead of setting 6 X 6's in concrete, floor joist not spaced at 16" on center. Why the odd ball joist spacing? Is this a metric lumber shed?
Sorry not impressed.
