Bathroom Demo 2013 - Project Showcase - Page 7 - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 06:51 PM   #91
Trucon01's Avatar
Rewards Points: 510
This was an absolute b!tch to cut...
Bathroom Demo 2013-photo-3.jpg   Bathroom Demo 2013-photo-1.jpg   Bathroom Demo 2013-photo-2.jpg
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 04-17-2013, 06:58 PM   #92
Rewards Points: 2,512
Not bad. WHat method did you use.
hammerlane is offline   Reply With Quote
Old 04-17-2013, 07:03 PM   #93
You main field tile is almost similar to what we did. did you think about throwing in a different accented tile in a few spots to break it up. This is what we did.
Old 04-17-2013, 07:18 PM   #94
Trucon01's Avatar
Rewards Points: 510
Ryobi angle grinder and patience...
Old 04-17-2013, 07:20 PM   #95
Trucon01's Avatar
Rewards Points: 510
What are the best screws to get to secure the flange to the floor?
Old 04-17-2013, 07:30 PM   #96
I used the tile bits to drill pilot holes thru the tile then #12 flat head wood screws to go into subfloor.
Im assuming your subfloor is wood or on you on a slab?
Old 04-17-2013, 07:31 PM   #97
ANd of course the screws were stainless.
Old 04-17-2013, 07:36 PM   #98
Trucon01's Avatar
Rewards Points: 510
Yea, I'm on top of plywood. Cool, as long as they won't rust!! Thanks
Old 04-17-2013, 08:11 PM   #99
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 434
your cuts look nice but with the cuts being along an edge it does make it a little bit easier. Trucon has to get into the interior on the tile piece without disturbing the edges.
Are those different colored tiles around the commode, shower and opposite edge or do some have a haze on them?
You're right. I also had an easier cut as I went around the flange so much larger radius.
Some of the tiles were dusty in the pic.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 04-18-2013, 08:28 AM   #100
Trucon01's Avatar
Rewards Points: 510
Correct?
$1.56
Crown Bolt #12 x 2 in. Stainless Steel Flat-Head Phillips Drive Wood Screw
Old 04-18-2013, 11:03 AM   #101
those will hold that flange nice and sturdy
Old 04-18-2013, 12:17 PM   #102
Trucon01's Avatar
Rewards Points: 510
When I go to grout the tiles, should I grout the line between the tile and the pan? Or should I leave that alone and just fill it with caulk?
Old 04-19-2013, 06:40 AM   #103
Either or.
Some say use caulk because it will have a little flexibility against the 4" riser coming up. Either way you want something in case of a leak you dont want the water seeping under.
My install was a little different. I had to reposition some drainage below so when I removed everything for the tile guy I just left everything open(but plugged like below) until he was done.
In post 71 you can see the tile guy just did around the hole in the first floor bathroom for the toilet. I installed the long sweep 90 into the flange after the tile was set.
Old 04-22-2013, 09:36 PM   #104
Trucon01's Avatar
Rewards Points: 510
Finally got around to finishing the tile... I will grout tomorrow afternoon.
Bathroom Demo 2013-photo-1.jpg   Bathroom Demo 2013-photo-2.jpg   Bathroom Demo 2013-photo-3.jpg
Old 04-23-2013, 06:46 AM   #105
Just a tip for what its worth. Use the 5/16" hold down bolts for the toilet to flange. They are a little bit meatier than the 1/4" ones and maybe a dollar or two more expensive.
Secure the bolts to the flange with xtra washers and bolts. This way the bolts are secure and wont move around when setting the bowl.
Bathroom demo day - dirt under the tub?? vsheetz Plumbing 16 07-25-2015 03:20 PM
bathroom exhaust connected to 26' of duct ChrisJJ HVAC 1 01-31-2013 11:50 AM
bathroom remodel complications megancn Building & Construction 6 07-24-2012 05:38 PM
Duct Work For Bathroom buildit45 HVAC 2 07-07-2012 10:36 PM
Using Bathroom Exhaust During Demo DetroitEE Building & Construction 10 01-17-2011 03:32 PM
