Bathroom Demo 2013 - Project Showcase - Page 5 - DIY Chatroom Home Improvement Forum
Old 04-10-2013, 12:50 PM   #61
Rewards Points: 578
Ahh man you shoulda left it pink! LOL just joking. That was some vibrant pink there, nearly hurt my eyes to look at it. It looks really great though, cant wait to see more.
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 04-10-2013, 08:27 PM   #62
Trucon01's Avatar
Rewards Points: 510
Installed the light and put on the duct register and the vent cover. Productive night!
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 04-10-2013, 11:03 PM   #63
nice! how high is it from the floor?
skyroofers is offline   Reply With Quote
Old 04-11-2013, 05:49 AM   #64
Rewards Points: 2,516
Due to their proximity, looks like the exhaust fan when operating may be drawing out any heat or cooling from the register. But if thats the hand you were dealt then it is what it is.
hammerlane is offline   Reply With Quote
Old 04-11-2013, 06:12 AM   #65
Trucon01's Avatar
Rewards Points: 510
The middle of the fixture is exactly 7 feet from the subfloor. The bottom of the light bulb is at 78".
Old 04-11-2013, 06:16 AM   #66
Trucon01's Avatar
Rewards Points: 510
Unfortunately, it was. When the ceiling was open, I had to keep it in between the the joists in that area or else I wouldn't have access to the soffit to install the vent. I guess I could have done more framing between the joists above and placed it in the shower area and then GFi'd the entire circuit at the box...
Old 04-11-2013, 07:16 PM   #67
Trucon01's Avatar
Rewards Points: 510
Installed P&S timer switch and cut / laid out Ditra.
Old 04-12-2013, 07:24 AM   #68
Timer for exhaust fan was a good call. How are you doing you toilet flange? even with finished floor or on top of finished floor?
Old 04-12-2013, 07:43 AM   #69
Trucon01's Avatar
Rewards Points: 510
I was reading a while back about the above or even with the finished floor topic. From everything I read, the consensus was on top of the finished floor, so that is what I was going to do. Correct?
Old 04-12-2013, 07:59 AM   #70
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,652
I ended up putting my flange on top of the concrete and with all the buttering of the tiles to get them level it was about 1/4" - 3/8" lower.
I used a thick wax ring and no problem.
It should have been a bit higher.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 04-12-2013, 08:02 AM   #71
This is probably a never ending debate. I vote for #1, on top of finished floor. Thats the way I did mine.
Old 04-12-2013, 08:06 AM   #72
Trucon01's Avatar
Rewards Points: 510
Any tool recommendation for cutting the hole in the tile around the flange?
Old 04-12-2013, 08:09 AM   #73
cuts with the wet-saw and nippers to get that hole.
Old 04-12-2013, 08:40 AM   #74
123pugsy's Avatar
4"blade in an angle grinder.
Old 04-12-2013, 08:46 AM   #75
Rewards Points: 202
I see you used Ditra on the floor. Would you recommend using it on a slightly out of level concrete floor (with some high and low spots)?
benleef is offline   Reply With Quote
Bathroom demo day - dirt under the tub?? vsheetz Plumbing 16 07-25-2015 02:20 PM
bathroom exhaust connected to 26' of duct ChrisJJ HVAC 1 01-31-2013 10:50 AM
bathroom remodel complications megancn Building & Construction 6 07-24-2012 04:38 PM
Duct Work For Bathroom buildit45 HVAC 2 07-07-2012 09:36 PM
Using Bathroom Exhaust During Demo DetroitEE Building & Construction 10 01-17-2011 02:32 PM
