-   Project Showcase (http://www.diychatroom.com/f49/)
-   -   Bathroom Demo 2013 (http://www.diychatroom.com/f49/bathroom-demo-2013-a-172426/)
Trucon01 02-19-2013 06:52 PM
Bathroom Demo 2013
5 Attachment(s)
Hi All,
After staring at a broken tile for about a year in the bathroom, I pulled it up to see what was underneath...
The top flooring was cheap tile installed for the prev owners flip, followed by 5 layers, yes, 5 layers of vinyl sheet flooring.
And the odd thing, the flooring got nicer and less dated as I went down...
joecaption 02-19-2013 07:15 PM
Your do plan on removing all if it, right?
Trucon01 02-19-2013 07:22 PM
Oh yes. All of it.
Trucon01 02-20-2013 09:53 AM
5 Attachment(s)
Removing sink, toilet and vinyl flooring
Trucon01 02-20-2013 09:55 AM
4 Attachment(s)
Under the vinyl was 3/8 plywood which is removed, exposing the sub-floor. I think it looks pretty good, minus the water damage near the toilet.
Thoughts?
Trucon01 02-20-2013 04:16 PM
3 Attachment(s)
Ripping down drywall... Shout out to Great Danes in pic 3
rebelranger 02-20-2013 05:55 PM
Wax gasket or rubber gasket? Is this bathroom in your basement?
Trucon01 02-20-2013 06:01 PM
No, this is the master bath in the master bedroom, which I use as an office. It had a wax ring.
I have a question which is posted in the Plumbing section if someone here can help.
The toilet is on a 3" ABS line and it had an outside 4x3 closet flange. I read that I can cut off the top of the flange, leaving the rest on the outside of the line and then use a 3" inside flange.
But I also read this would cut off the diameter too much. What can / should I be doing here?
Trucon01 02-25-2013 08:06 PM
2 Attachment(s)
After taking out the tile, the base was not screwed to the studs, anywhere...
Trucon01 02-25-2013 08:17 PM
4 Attachment(s)
Here are a few more pics of the shower all opened up.
Trucon01 02-26-2013 08:03 PM
2 Attachment(s)
One bag of Roxul in. This stuff is great!!
Trucon01 03-01-2013 08:40 PM
2 Attachment(s)
Contractor grade fan vs Nutone 130 CFM...
Trucon01 03-05-2013 12:41 PM
130 CFM exhaust fan installed w/ video... The 90 deg elbow will be in the soffit attached to a 4" slotted and screened vent.
Exhaust Fan... Click Here to view
Trucon01 03-05-2013 09:45 PM
4 Attachment(s)
Got up some drywall and put down new plywood over the existing 19/32.
Trucon01 03-11-2013 07:46 PM
1 Attachment(s)
Installed Tile Redy insert
