Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 08-04-2011, 12:57 AM   #1
Basement Subfloor Error?
So I started laying the subfloor down in my basement, when it dawned on me that I didn't leave an expansion gap around the perimeter of the room.. I already have the subfloor screwed down with tapcons also... Here is a picture:
What do you guys suggest I do?? Think I'll be OK without the expansion gap, as it's in the basement, and should stay relatively one temperature all the time.. Or should I somehow shorten the subfloor up?
casper129 is offline   Reply With Quote
Old 08-04-2011, 02:38 AM   #2
Dorf dude...
shumakerscott's Avatar
If you only have to unscrew it then pull it up and leave a small gap. You will regret it if you don't. If you don't want to unscrew it then it's a great excuse to buy a Fein Multimaster! dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 08-15-2011, 02:11 AM   #3
I would just rent a jam saw and use it on the floor instead of the wall and be done with it. Save time money and the headache of having to remove and re-install the flooring
fixrite is offline   Reply With Quote
Old 08-15-2011, 02:35 AM   #4
^ Thanks for that tip! I already took up the few sheets I had screwed down, and the rest that I didn't and trimmed them with circular saw, and just moved over what I could...
I never even knew of a jamb saw... I may have to look into getting one for the rest of the basement. I'm sure I could use it somewhere
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 03:26 PM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 04:26 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
