Basement Project - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 09:10 PM   #16
Very Nice Job!
I have a question, how did you attach the pink foam board insulation? I'm assuming that it's glued to a cement wall and if so, how did you glue it and what type of glue did you use?
I have to do the same in my basement and had a problem with it sticking to the wall. I ended up nailing it to the backside of the stud wall. I like what you did and want to know your process.
Thanks,
John
fmj67 is offline   Reply With Quote
Old 02-22-2010, 09:20 AM   #17
Looks great. Adds a lot of space too. Were there any bathroom pictures posted as I didn't see any?
seawiz is offline   Reply With Quote
Old 02-23-2010, 07:18 AM   #18
There weren't. They'll be coming around the mountain when he's done!
Lali is offline   Reply With Quote
Old 03-09-2010, 01:28 PM   #19
Rewards Points: 640
Hey how high are your ceilings down there? I am working on plans for mine and I have 97" from concrete to joist then lose 10" of that where the duct work goes through...
BlueBSH is offline   Reply With Quote
Old 03-09-2010, 01:39 PM   #20
Originally Posted by GunMetal87 View Post
Awesome color! Perfect for my new office, what color is it?
Sherwin Williams - Cityscape (I believe). It's actually a bit less grey and a bit more blue than what it appears to look like here.
ThunderCAT is offline   Reply With Quote
Old 03-09-2010, 01:41 PM   #21
Originally Posted by fmj67 View Post
Very Nice Job!
Thanks,
John
Not 100% sure on what the adhesive was called at the moment. Purchased it from Menards. Just need to make sure it's compatible with foam substrate. I didn't have any problems with it not sticking and it was glued to a poured cement wall.
Old 03-09-2010, 01:44 PM   #22
I need to apologize...I've been done for awhile (since mid-June last year) but have neglected to take any photos! Totally forgot! I did just put the shower door in last weekend (officially the LAST thing that needed to be done).
I'll take some tonight and post. Word of warning...there will be a lot of toys in the pictures! The space has been a great place for our family and little one to hang out. We spend a lot of time down there and it's nice to have his toys downstairs out of the main level (well, most of his toys are out of the main level, he still has enough up there to keep him busy!).
Old 03-09-2010, 01:45 PM   #23
We had 9' ceilings down there. The soffiits are around a 12" drop, so 8' celings around the ductwork and in the bathroom (due to a support beam).
Old 03-09-2010, 04:39 PM   #24
Here are some pictures just after carpet install in June '09 - carpet was a little darker than we wanted, but still looks pretty good. Will hide some of the wear and tear and inevitable stains from our son's antics throughout the years (he's 2 and 1/2 now).
Basement Project-carpet-001.jpg   Basement Project-carpet-002.jpg   Basement Project-carpet-005.2.jpg
Old 03-09-2010, 05:06 PM   #25
Here it is finished (after about 9 months of full use). I warned you about the toys! Our son's a sports freak already at 2.5 yrs old, so we play a lot of hockey, basketball and football in the basement. My wife would certainly love to decorate more fully down there, but just no need right now until our son gets a little older, and hopefully more in control of his slap shot! Ideally we'd have black leather furniture, but we had the brown stuff in a different room of the house, so for now it will do. Also need a better media center organizer. What we have now is just a coffee table borrowed from elsewhere in the house. The TV, in case anyone is wondering, is a 58-inch Samsung plasma. I went with it because it's only a little over an inch thick, and because of the wall it's on I wanted it to be as slim as possible (it's also mounted on a slim-mount). It's picture is awesome!
By far the best $ invested in the house so far. On a $ per sq ft basis, the entire project was really cheap. Also, as stated previously, bathroom is difficult to get pics of due to size. We live in MN, and the fireplace was a key addition for us. We use it a lot to take the cool edge off down there. My entire basement is below grade, and even though I fully insulated it and have plenty of ductwork take-offs, it still gets a little colder down there than preferred. Also made the little chalkboard for my son and his friends/cousins. Couple coats of magnetic paint overlaid by a couple coats of chalkboard paint and trimmed out. As you can see, it gets a lot of use! I should have used another coat of magnetic paint (or two), but it serves it's purpose.
I often get asked if I would do anything different...a couple of things:
1. Make the playroom a bit bigger. It's currently about 10.5x11. But in the future it will be used as an office or craft room, in which case size will be fine.
2. I should have planned my TV area a little better and developed a media area off to the side rather than needing to have the components, gaming systems and set top boxes directly underneath.
3. I wish I would have done better/more soundproofing directly around the speakers as I get a little bit of noise in the main level above the in-ceilings. I did wrap the ductwork with Dynamat, which helped a lot (especially with blocking noise traveling up to the second level, which we get none of).
4. I used Dupont laminate wood flooring from HD in the landing and bathroom. Wish I would have used tile. Laminate is already scratched...need to look into warranty on this.
5. The trim in the rest of the house is maple with white doors - the basement's look and feel is a bit different with the white trim. I wish I would have use maple trim to match the rest of the house.
All in all for my first big interior DIY project, not too bad and we're very pleased with it. Please let me know if you have any questions!
Basement Project-familyroom3.jpg   Basement Project-familyroom2.jpg   Basement Project-chalkboard.jpg   Basement Project-bathroom.jpg   Basement Project-landing.jpg
Old 03-09-2010, 06:17 PM   #26
Landscaper
Nice work!! Looks great!
DBRhino is offline   Reply With Quote
Old 03-09-2010, 06:27 PM   #27
Rewards Points: 87
Good job with the remodel !
Stephen S. is offline   Reply With Quote
My Basement Project sail3695 Building & Construction 4 01-05-2009 08:03 PM
Basement project rjamesh Building & Construction 4 10-11-2008 07:03 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
My basement finishing project DIY4EVER Project Showcase 6 02-18-2008 08:21 PM
A newbie basement finishing project DIY4EVER Building & Construction 6 05-11-2007 09:48 AM
