Basement Project - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-23-2008, 04:44 PM   #16
Rewards Points: 1,910
Looks great! I bet your feeling pretty good about being so close to done. But now what are you going to do on weekends!
Old 01-26-2008, 07:47 PM   #17
Looks awesome, Im not looking forward to all the drywall work though...
Demochick is offline   Reply With Quote
Old 01-26-2008, 08:49 PM   #18
Rewards Points: 31
Thanks, got the vinyl in today and hung the last two doors. A bit more trim to finish tomorrow then I'll snap a few more pics.
Mdbuilder is offline   Reply With Quote
Old 01-27-2008, 02:01 PM   #19
Is that wood in the other pics? or vinyl? if wood how did you secure the last pc.? looks good
big daddy-o is offline   Reply With Quote
Old 01-27-2008, 03:52 PM   #20
Rewards Points: 31
It is laminate from Lowes. It's a floating floor with a vapor barrier underneath, each board is 3 strips wide so about 8 or 9 inches wide "click together"
Old 01-27-2008, 03:57 PM   #21
ok but what about the last pc? how doyou keep it togather ?
Old 01-27-2008, 05:11 PM   #22
Rewards Points: 31
Each board interlocks, when you get to the end the last piece will generally be too wide so you rip it down on the table saw to a width about a 1/2" short of the wall. Then just engage the joint and fold it down in place with some general tapping, wrestling and maybe a curse or two . Base and quarter round covers the gap. In my case I laid the floor before the drywall so in large areas where I did a good job just the thickness of the drywall and the base board was enough. On the outside wall I drifted out a bit too far on one end so I had to add the quarter round. Doorways get T moldings or transition strips.
Old 01-28-2008, 08:12 AM   #23
Rewards Points: 31
Got the vinyl down over the weekend along with most of the trim, painted the french door and removed the masking. I have a bit more base molding still to do and then about a million nail holes to fill before the trim gets it's finish coat of paint
Basement Project-basement-trim2002-small.jpg   Basement Project-basement-trim2005-small.jpg   Basement Project-basement-trim2006-small.jpg   Basement Project-basement-trim2009-small.jpg
Old 02-03-2008, 10:28 PM   #24
Its a nice to see u r frames they are really nice.
presentationma is offline   Reply With Quote
Old 02-11-2008, 09:58 AM   #25
Now this is inspiration !!!
Very nice job.
raam is offline   Reply With Quote
Old 02-11-2008, 10:09 AM   #26
Rewards Points: 31
Thanks .
I did a little caulking and nailhole filling on the base and door trim over the weekend. Probably about 50% finished with that. The pressure is off now that the major construction is finished, it's basically usable space as I go about handling the final details...
Old 06-22-2008, 07:48 PM   #27
Rewards Points: 31
It's been a while! Still haven't finished all the nail hole filling and trim painting but I did get the electrician back to heat up all the new outlets and had the inspecter back last week to sign off on the final
This weekends project was the first of 3 bookcases to organize things. Got one done today, 3/4" birch ply for the carcass, 1/4 luan with one good side for the back. A little 3/4" poplar ripped down to cover the front edges then a little roundover work with the router and some crown added at the top.
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
A newbie basement finishing project DIY4EVER Building & Construction 6 05-11-2007 09:48 AM
