Basement Flooring Project - Project Showcase - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 04:16 PM   #1
basement flooring project
Went from some ugly light blue and brown ceramic tile, covered it with Allure TrafficMaster (big mistake), to slate 12x12 tile. i've been working on this room for going on 2 weeks. It took 3 days just to break up and remove the old tile and remove the Allure flooring i had put down.
Just finished this tile job...in the process now of sealing and grouting.
PorgyLuvzBess is offline   Reply With Quote
Old 08-24-2011, 05:05 PM   #2
DIY staff
Rewards Points: 7,174
Looks good---that slate looks like a grouting nightmare---good luck!
Old 08-24-2011, 06:39 PM   #3
DIY staff
What's in that bucket?
Old 08-24-2011, 07:13 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Oh-oh!
XXX
Old 08-24-2011, 07:52 PM   #5
Thin-set.
Old 08-24-2011, 07:58 PM   #6
DIY staff
Thinset comes in bags not buckets---You may be in trouble---
Old 08-24-2011, 08:04 PM   #7
DIY staff
"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
interesting read---
Old 08-24-2011, 08:08 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I think I did see at Home Depot a bucket of (so-called) pre-mixed thinset labeled "For use with natural stone tile". Is that what's in the bucket?
XXX
Old 08-24-2011, 08:12 PM   #9
The pre-mix is no good? Please, explain the difference.
Old 08-24-2011, 08:26 PM   #10
DIY staff
Cement based thinset set by hydration(?) ---It is like concrete--it doesn't need air to set--it gets hard with time.
Adhesives in a bucket need to dry---hows long will depend on how much air gets to it.
Covering a bed of adhesive with a 12x12 tile pretty much stops the air from reaching the center.
Then the are other issues---strength and compression---and water solubility. That bucket adhesive will turn back to liquid if ever exposed to water.
Typically adhesive is only used for smaller tile on walls in dry areas.------Mike----
Old 08-24-2011, 08:30 PM   #11
DIY staff
I feel bad---I thought you knew---
Old 08-24-2011, 08:36 PM   #12
Wow...I didn't know that and I'm sure the instructions on thr bucket make no mention of that. Needless to say I would actually not mind having to lay the tile again. As long as I don't have to break it up. That was hell. So if water loosens the tile and they separate from the floor, I'll get some bagged thin set and lay them again.
I'm gonna be doing the other half of the basement but with ceramic tile. What thinset do u recommend?
Old 08-24-2011, 08:43 PM   #13
DIY staff
Any good modified thinset will do--
Modified contains a powdered latex and it sticks well --also has a long pot life--1 1'2 to 2 hours in the bucket after mixing.
A 1/2" drill and mixing wand is VERY helpful---Read that link "mud what is it" that offers a good simple explanation.
-----Mike---
Old 08-25-2011, 09:36 AM   #14
So what's the worst I can expect to happen with the bucket/pre-mixed gunk on my floor? should i pull up the tiles and lay them again or should i hope for the best and repair them if and when they come up?
as of right now, they seem in place and solid. what would you do?
Old 08-25-2011, 08:58 PM   #15
DIY staff
Let the installation stay----The tiles will be to much trouble to clean completely---If it fails then re do it--Cross your fingers---and do the next one right.
The only people who don't make mistakes are people who never do anything.
decision point in my exterior basement waterproofing project c2g Building & Construction 7 03-02-2011 06:41 PM
basement flooring afaller Building & Construction 5 01-05-2011 04:47 PM
My Basement Project sail3695 Building & Construction 4 01-05-2009 09:03 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 07:02 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
