Basement Finishing - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 12:47 PM   #16
Thanks for the comment. This isn't necessarily going to be completely diy. I do anticipate hiring a structural engineer to analyze the foundation and the size of the window vs need for structural support. It is going to be a rather long process but I am ok with that.
I am going to put up studs/framing. I debated fitting it out vs all inclusive products and I decided it would be easier and effective to just frame in the space.
cscpianoman is offline   Reply With Quote
Old 08-10-2012, 10:49 AM   #17
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Originally Posted by katewatson View Post
What's the best thing to do to prevent basement leak?
Make sure your grading is properly sloped away from the house, your downspouts are positioned properly, and your sump pumps are in good working order. Unless you have a really high water table, if you keep the water away from the outsides of your basement walls, it won't want to come inside.
hyunelan2 is offline   Reply With Quote
Old 02-03-2013, 02:34 PM   #18
Still alive and working
Just an update on the whole process. I haven't been sitting too idle
I just finished the layout yesterday. Not too bad, though looking up at the ceiling there will be some obstacles to get around for the framing.
The bedroom is 3/4 framed. The far wall has to have an egress window put in, but that will have to wait til spring.
Budget-wise I am only limited to about $150/mo for now. I start a new job in another week that will help to finish off the rest of the basement. In the meantime I get to finish in bits and spurts.
Basement Finishing-imag0050.jpg   Basement Finishing-imag0051.jpg   Basement Finishing-imag0052.jpg   Basement Finishing-imag0053.jpg   Basement Finishing-imag0054.jpg
The Following User Says Thank You to cscpianoman For This Useful Post:
shumakerscott (02-05-2013)
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 09:41 AM
Finishing basement - insulation problem? Gooter Building & Construction 6 08-24-2009 08:23 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
Finishing basement - low ceilings alyuka Remodeling 1 01-05-2009 08:13 PM
finishing a basement jimmyfloyd Building & Construction 2 10-21-2008 12:30 PM
