Basement Finished!!! - Project Showcase - DIY Chatroom Home Improvement Forum
Old 03-26-2007, 04:17 PM   #1
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Cool
Basement finished!!!
Well, I started the day after Christmas, 2006. Here it is, March 26th, 2007 and I'm done. I just need to mount the door to the area under the stairs and decide on furniture. Carpet installers didn't mess up any paint!
I did this project almost entirely myself. I started with bare concrete wall. Only parts subbed out were the drywall and the carpet install. I did all the carpenty (Rough and finish), plumbing, electrical, insulation, painting, fireplace, etc.
Here are a couple of pictures
Brik is offline   Reply With Quote
Old 03-26-2007, 04:25 PM   #2
Well done... I hope when I post my pictures.. which may be a month more later... I would be as good or better... really don't know yet... but very nice of yours....
KUIPORNG is offline   Reply With Quote
Old 03-26-2007, 04:27 PM   #3
Handyguy
Brik's Avatar
BTW - Thanks for the praise and for all your input along the way.
Old 03-26-2007, 05:26 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Looks great...
- Build Well -
Old 03-26-2007, 06:22 PM   #5
looks nice I was kind of considering doing that to my basement because everything is just concrete.
New2dis is offline   Reply With Quote
Old 03-26-2007, 07:44 PM   #6
Remodeler
MinConst's Avatar
Nice job Brik. Looks real nice. Enjoy it now.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 03-26-2007, 08:38 PM   #7
yummy mummy's Avatar
Rewards Points: 1,016
Really nice brik!
I hope mine will look as good, whenever I finish.
yummy mummy is offline   Reply With Quote
Old 03-26-2007, 09:44 PM   #8
Master Craftsman
Big Dave's Avatar
Looks great.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 03-26-2007, 10:10 PM   #9
Brik do you have any before pictures?
Old 03-27-2007, 08:31 AM   #10
Handyguy
Brik's Avatar
No before pictures, a couple of in progress pictures is all I have.
Essentially I started with bare concrete walls, concrete floor, exposed floor joists above, 3 bulb sockets for lightiing and hvac ducts running down the middle. Typical unfinished basement.
You cant see in the picture but the mechanicals (HW heater, furnace) are under the stairs. I needed to move the water heater to its spot under the stairs. I also needed to move the water meter. It was origionally at the bottom of the stairs and stuck out almost 18" from the wall.
The space behind the door next to the fireplace is unfinished storage. The picture with two doors in the 'yellow' room. One is a closet, the other leads to a home office that was finished 2 years ago. (~150sqft).
Old 03-27-2007, 10:08 AM   #11
Is this a hard job? is it very expensive? I don't wish to hide my boiler or meters I just want to lay down flooring & sheet rock the walls.
Old 03-27-2007, 10:36 AM   #12
Handyguy
Brik's Avatar
Is what, specificly, a hard job? Moving the water heater was easy. It did involve some planning and the ability to solder copper pipe, work with a pvc vent and to work with gas pipe. I suppose easy it relative. It took about an hour. Would be even easier if electric. Moving the water meter is a little harder. It involved shutting off the city water and requires a special tool to be used in the street, in my case, once the water is off its easy to cut and solder pipe to get things to their new location.
If you are asking about the whole project. No, its not too hard. Know your limitations and also ask yourself what your time is worth. Like I said, I paid to have the drywall put up. It would have taken me 6 to 8 weeks, or more, to do it my myself. Paying someone it only took 4 days.
Keep in mind they prooject is SIGNIFICANTLY more complex than "I just want to lay down flooring & sheet rock the walls" if you cant envision ALL the other things that need to happen before and after these two steps then you may be in over your head.
As for cost - I didn't keep track. I would guestimate that the entire thing cost me $11,000 to $13,000. $2500 for drywall, $3,500 for carpet and pad and $3,000 for the fireplace were my biggest expenses. Framing was maybe $400, insulation maybe $300, electrical was maybe 3 or $400, plumbing was maybe $100 (no new, just relocating valves, water heater and meter). Trim and doors was maybe $400. Paint was maybe $300. I'm probably missing a bunch of stuff too.
Also, I am not counting tool costs. I already had a full compliment of tools.
Now there will also be furniture, surround sound, etc. That will add up quickly.
Old 03-27-2007, 10:46 AM   #13
I wish I have kept my cost also... I also lose check... If you do yours, I suggest you use a special credit card for all your expense to keep track of the cost... in my case, I could have apply the HD card and track cost there.... I got it kind of too late... now I have no idea how much it cost me either...
Tracking cost is a good information to tell your Boss or friends as they always ask this question...
Old 03-27-2007, 10:48 AM   #14
If you want to keep all figures, it's good to also keep track of your time (hours you have put into the project).
I know, that when I am tracking costs on projects, I even account for gas usage for picking up materials....
- Build Well -
Old 03-27-2007, 10:58 AM   #15
Thanks Brik
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Can floor jacks in basement be permanent? ragtopdave06 Remodeling 15 03-15-2007 06:23 PM
Installing Registers in finished basement boinger HVAC 2 02-07-2007 04:44 PM
