Basement Bath Remodel - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 01:15 PM   #16
Rewards Points: 202
Originally Posted by hammerlane View Post
They are rolled somewhat. How much is hard to tell. The shower takeoff looks more so than the toilet since the toilet vent takes a quick 90 out of the tap of that Tee.
So is this an issue or are you just trying to make me nervous?
benleef is offline   Reply With Quote
Old 03-26-2013, 06:42 AM   #17
Rewards Points: 2,516
I wouldnt lose any sleep. I dont think those horizontal sections of those vents will ever clog but wonder why he did not run the toilet flat portion straight to the wall and then up. Flat vents are suppose to be as short as possible.
Relax and enjoy your new bathroom
hammerlane is offline   Reply With Quote
Old 03-26-2013, 07:49 AM   #18
Rewards Points: 202
That makes sense. Not sure why he chose to do it that way. Thanks!
Old 04-08-2013, 08:51 AM   #19
Rewards Points: 202
Some Progress. I decided to take the opportunity to clean up all the wiring that was in the area and run in through the new stud wall instead of stapled perpendicular to the ceiling joists. This was quite a bit of work, but I think it turned out OK. I plan to run two circuits the the laundry area which sits under the kitchen for future kitchen circuits when we get to the kitchen remodel.
I also still have to run the bathroom circuit but am waiting until pluming is complete.
Also, I re-did the stairs going to the basement a couple months ago. I still have to stain and poly them but figured I would wait until after the remodel is done.
Basement Bath Remodel-old-wires.jpg   Basement Bath Remodel-new-wires.jpg   Basement Bath Remodel-stairs-old.jpg   Basement Bath Remodel-stairs-new.jpg
Old 05-02-2013, 09:03 AM   #20
Rewards Points: 202
It has been a busy couple of weeks,
I poured self leveling cement on the floor. It was my first time using the stuff, so I didn't do a perfect job, but I got it much flatter.
I sistered the ceiling joists to level and flatten the ceiling. I decided to do it this way because if I ran furring strips perpendicular I'd loose at least 3/4" all around, this way, I lost 3/4" at most. I borrowed a friend's laser level, which made things incredibly easy.
My plumber friend finished the plumbing. Except for the pluming vent, which I need to finish--I'm running it horizontal for about 8 feet and then up a chase that I am going to build along the chimney all the way up to the roof. Not looking forward to that job!
Shower floor is installed. Set it in a bag of mortar. Feels quite solid. There are a couple spots that feel a little hollow--I'm going to try to shove some more mortar under there while I still have access just for good measure.
Exhaust vent is installed. Turned out to be much easier than I thought it was going to be.
Still plenty more to do....
Old 05-03-2013, 02:24 PM   #21
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Here is a random question for you: Did you just drill a 4" hole through the rim joist for that fan? Is that OK to do since most of the stability of that joist is just from stuff sitting on top of it?
CoconutPete is offline   Reply With Quote
Old 05-03-2013, 02:40 PM   #22
Rewards Points: 202
It is not through the rim joist. It is actually just through the old tongue and grove outside siding. It is above the sill plate. The house is what I believe balloon construction.
However, I've heard that drilling through the rim joist (even 4") hole is fine as long as it is not under a stud or main support (like under a window).
Old 01-14-2014, 10:13 AM   #23
Rewards Points: 202
So I finally finished the remodel back around August, but haven't had a chance to upload some pics. Figured maybe someone would be interested in seeing the progress.
Basement Bath Remodel-1.jpg   Basement Bath Remodel-2.jpg   Basement Bath Remodel-3.jpg   Basement Bath Remodel-4.jpg   Basement Bath Remodel-photo-1-3-.jpg
Old 01-14-2014, 10:15 AM   #24
Rewards Points: 202
more pictures
Basement Bath Remodel-photo-1.jpg   Basement Bath Remodel-photo-2-3-.jpg   Basement Bath Remodel-photo-2.jpg   Basement Bath Remodel-photo-5.jpg
Old 01-14-2014, 10:17 AM   #25
Rewards Points: 202
before and after shots (or after and before shots):
Old 01-14-2014, 11:49 AM   #26
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 936
Very nice transformation.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 01-14-2014, 12:02 PM   #27
Rewards Points: 202
Thanks! My father is a contractor, so growing up I learned a lot, but this was my first major project as my own contractor... I learned a ton working on found out that doing this kind of work is my hobby. Unfortunately when I was a lazy teenager I didn't like when my dad asked for my help!
Old 01-14-2014, 03:22 PM   #28
123pugsy's Avatar
Rewards Points: 936
Ha!
I was exactly the same for anything to do with construction or renovation stuff when I was young.
Basement remodel Badfish740 Project Showcase 4 06-08-2012 06:31 PM
Colors & Decorating Advice for Basement Remodel gunderson99 Painting 3 07-05-2011 11:19 AM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 02:55 PM
Tie into existing bath GFI circuit for new basement bath GFI? 8roty Electrical 8 07-27-2009 11:38 PM
Bucket in concrete for full bath in basement? Leoskee Plumbing 18 08-26-2008 03:27 PM
