Backyard Skating Rink - Project Showcase - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 07:54 PM   #1
Backyard skating rink
Rink building amateur style
This project will proceed with the co-operating winter temps.
Decide on the size of your rink. Keep in mind the regular winter maintenance will now be like shoveling 2 driveways. Except you have to scrape off that last inch or two.
Mine will be approx 75' x 30'
Start at the highest point on the lawn. It is much easier to raise your boards up to level then it is to dig out the ground.
Pound in the first stake. Remember to pound in deep enough that the stake does not show above the board. Dangerous to fall on and hard on the tarp. Drill it to the board.
The force of water and ice is enormous so be sure to attach stakes at the ends of each board and one in the middle. Make sure your boards are level
Backyard skating rink-f_18.jpg   Backyard skating rink-2012-11-16-19.24.53.jpg
creeper is offline   Reply With Quote
Old 11-16-2012, 08:04 PM   #2
Continue on around the perimeter. We are not making fine furniture here, A rough frame is good enough. The borders will be covered with snow banks anyway.
The gaps underneath will be filled in with cheap fence boards and the low spots will be built up to accomodate the extra depth of water. In my case the difference will be at least 8- 10 inches.
Backyard skating rink-di.jpg   Backyard skating rink-sh.jpg   Backyard skating rink-d_06.jpg
Old 11-17-2012, 08:51 AM   #3
shadytrake's Avatar
Rewards Points: 364
Now that is an interesting project.
shadytrake is offline   Reply With Quote
The Following User Says Thank You to shadytrake For This Useful Post:
creeper (11-17-2012)
Old 11-17-2012, 10:37 AM   #4
Post boards and tarp are the next step. As well as tips to avoid shell ice
Old 11-18-2012, 10:33 PM   #5
Although the yard appears flat, you can see how uneven it really is by the space underneath some of the boards.
I will fill in the underneath gaps with fence boards.
In order to fill one end to a minimum depth of two inches, the low end will take 8-10 inches of water. Add another board across the top and don't forget to leave enough tarp to accomodate the height.
Backyard skating rink-2012-11-18-17.32.03.jpg   Backyard skating rink-2012-11-18-17.33.25.jpg
Old 11-18-2012, 10:44 PM   #6
Wait until you are ready to start filling before laying the tarp.
The tarp should be white or clear to reflect the sun.
Any leaves imbedded in the ice will cause the ice to melt. That spot will become a tripping hazard.
Don't fill until the sub zero temps are consistent for a few days. Fill only a few inches deep at a time. Let it freeze solid before adding another layer
If its extremely cold fill the rink in one session otherwise the second layer may not stick to the first layer and you could end up with shell ice.
The Following User Says Thank You to creeper For This Useful Post:
gma2rjc (11-18-2012)
Old 11-18-2012, 10:53 PM   #7
Rewards Points: 336
This is cool. I can't wait to see it filled. Thanks for posting the pics Jan.
Do you do this every year?
Since when do people up in Canada play hockey?
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
creeper (11-18-2012)
Old 11-18-2012, 11:11 PM   #8
Thanks Barb. This is only my second year, but I learned alot the first time. This one is huge. I may be too tired to skate after clearing it off all the time.
Speaking of hockey. The good news about the strike is that for the first time the Toronto Maple Flops haven't lost a game all season. Jokes
Resist the urge to paint blue lines on the tarp or ice. The sun will be attracted to those spots.
If the deep cold doesn't set in before Christmas, I have a feeling Santa may stop by Costco for a really cool net with extended webbing so that mothers with lousy aim don't send the puck flying out of bounds.
Trudging through the snow with skates on can be a bit of a challenge.
Old 11-18-2012, 11:38 PM   #9
Rewards Points: 336
I forgot about there being no hockey on tv this year.
Do the kiddo's help keep the ice rink clear?
Old 11-18-2012, 11:45 PM   #10
You say funny things Barb.
No they just skuff it up. Then while I stay out to flood it for a nice smooth surface for the next day, they go in and skuff up the inside.
Old 11-19-2012, 05:31 AM   #11
Rewards Points: 2,238
creeper -
Do you have to run the Zamboni!?!
rossfingal is online now   Reply With Quote
Old 11-19-2012, 05:51 AM   #12
Why Yes, yes I do . Thats the best part.
Its a hand held one with its own shut off valve. I hook it up to the hose and run it to the laundry room.
Hot water works best. It really smooths out any gouges made from blades.
But we've gotten ahead of ourselves. I will post about that, with pictures in the near future.
Old 11-19-2012, 06:44 AM   #13
Wow!
Work, parenting, and, now - a "Zamboni"!
That's what I call "multitasking"!
(One question - you did get a permit? -didn't you?!?)
Old 11-19-2012, 07:00 AM   #14
Thanks for getting it Rossi.
There is definitely mulitple things going on. Always.
Thank goodness for my daytimer.
Now only if my head will stop spinning long enough to write stuff down in it
...Just looked in it. I have to be in two places at the same time this am....oops
Old 11-19-2012, 08:39 AM   #15
"Head spinning"!!!
Now you sound like Linda Blair in the movie "Exorcist"!
(I like "pea-soup"!)
Can we get some video?!?
Adding dirt to backyard ricksample Landscaping & Lawn Care 6 11-13-2011 11:58 AM
Landscaping Ideas for Small Backyard? gammy4gks Landscaping & Lawn Care 2 08-08-2011 09:25 AM
lowering backyard level & window to crawl space greenpointer Building & Construction 2 03-14-2011 08:40 AM
Water Pipe Leak in Backyard diginside Plumbing 2 07-08-2010 05:50 PM
Backyard skating rink timp General DIY Discussions 6 11-30-2007 09:43 AM
