Backyard Fence (Part 1) - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-11-2010, 09:25 AM   #16
biggidybankston's Avatar
I used a 2x2 tie found at the Home Depot with deck screws:
biggidybankston is offline   Reply With Quote
Old 10-12-2010, 10:36 PM   #17
Rewards Points: 262
I have never had luck setting posts ahead of time while installing pre-made fence sections. They always tend to travel and end up too close or far apart from each other. What works for me is to set and plumb one post then one section at a time, step back and make sure the sections are still in line with my guideline.
As far as constructing a gate. The best tip I've seen is to construct the gate and posts on a flat surface as one unit complete with hardware and frame in top and bottom of the gate with 2x4's to be removed later. Then the entire unit lifted and placed in the two post holes which are filled with concrete. If you connect both posts with concrete in a trench in between, that will give it more stability and prevent grass and weeds from growing under your gate. I did not do it this way but definitely will when I eventually redo my gates.
Incidentally, I really like the gate in the picture.
Jim F is offline   Reply With Quote
Old 11-14-2010, 07:51 PM   #18
Originally Posted by Grif110 View Post
I'm building a similar gate and have a few questions I hope someone can answer.
1. In the bottom panel, should the boards be glued together as a single panel and then allow for expansion/contraction on the sides or should all the panel boards be loose? The panel boards on my fence are tongue and grooved, so if i were to leave them loose, should I put a brad in the center of each board (top and bottom) to allow each one the expand and contract?
2. How are the 2X2 slats in the top attached? I was thinking of using dowels on mine, but it seems like alot of work. Better solution?
Well, I finally finished (ok, 98% finished) this project. It is a gate and two fence panels that run from the house to the garage under the breezeway. It was a lot more work than I expected, but I am pleased with the result.
Grif110 is offline   Reply With Quote
Old 11-15-2010, 12:00 PM   #19
Custom User Title
Rewards Points: 252
That looks great!
no1hustler is offline   Reply With Quote
Old 12-01-2010, 04:16 AM   #20
Knucklez's Avatar
Rewards Points: 930
this is the best website for learning & sharing. thanks for this tip. i have two gates to build next spring so this will come in handy.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 12-05-2010, 12:44 AM   #21
jackie treehorn's Avatar
Rewards Points: 174
that looks real nice, good job!!
jackie treehorn is offline   Reply With Quote
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 07:03 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 04:39 PM
Question for paying for backyard fence. SuperAkuma Landscaping & Lawn Care 15 08-14-2008 08:39 AM
2x100a sub on service main jambud Electrical 17 03-12-2008 10:31 AM
