The Arch Is Complete - Project Showcase - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 08:19 PM   #1
Military Mom of 4
Snav's Avatar
The Arch is complete
(scroll to the bottom to see it textured and painted)
Height: 7'4", width: 7'1"
Took 3 days to frame and drywall - now I need to mud and texture.
No - it was not easy. Will I do it again? Probably not. But I wanted one so I made one.
To make the arched part of the doorway: I hung a sheet of ply from the ceiling and traced the squared-door opening onto it. Then I was able to remove this sheet, carried that outside - and drew the shape of the arch onto one-half of it using a 1" wide reed that came off of an old set of venetian-blinds (wood). This was reasonably flexible - yet not too stiff and shaped a curve quite nicely.
I used this sketched arch as a template to make vertical struts of 2x4 - using the curve drawn on thy plywood to transfer the angles to the 2x4's and set the skill saw accordingly (my miter saw died) - this made things more time consuming but still got the job done.
Then I carefully transferred these cut 2x4's to the rough cut opening per precise measurements.
On the underside of these I adhered 1/4" plywood that was shaped using a wet-method that I'd like to name "too lazy to shape in a steam box so I wet it down and then cooked it with a blow-dryer" (I'd like to thank the academy) - which worked great. As it relaxed I was able to tighten screws all along each piece to get it to hug to the 2x4 struts.
I let this dry.
Then I dry-walled - the only tricky part here was cutting the curved underpiece. I cut that to the needed width and every 2" I scored the back - if this was bending wood this would be a kerf-cut method. I then applied a layer of mud to the ply to act as a temporary adhesive so I could apply the scored pieces of drywall and attach it all with a bounty of screws.
tada - done. So simple!
The center of the arch - you know, I should have KNOWN this was going to happen: the illusion of it sagging. It's *not* actually sagging - it's perfectly flat and level there. But! With the springers (curved portion of the arch) and so on in place it makes it look like it's sagging. When I mud and texture I'll take care of this false sense of imperfection. The Greeks learned this, too - and thus the Parthenon is 'perfectly imperfect' But I promise - it's not actually falling down. It just looks like it from some angles.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 09-21-2011, 08:39 PM   #2
Framing Contractor
Rewards Points: 96
A little late to say this, but there is an easier way. You had the right idea with the plywood. Use a piece for each side and infill between with 2x4's following the curve. Then use 1/4" drywall to follow the curve. The radius of the curve can be easily calculated with a construction calculator or an online calculator. If you know the length, and the total height, the calculator will give you the radius.
sixeightten is online now   Reply With Quote
Old 09-21-2011, 08:54 PM   #3
Military Mom of 4
Snav's Avatar
Yes - that would have been easier. But that would have required me to borrow my dad's truck and drive into town for a sheet of plywood.
I just didn't feel like it.
Somehow - when I'm lazy - things get more tedious. Total woman for ya.
Old 09-21-2011, 09:20 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Nice! Looking forward to seeing it finished.
Doc Holliday is offline   Reply With Quote
Old 09-21-2011, 09:22 PM   #5
Painted is what I meant, if you're painting.
Old 09-21-2011, 09:26 PM   #6
I've seen that done on hgtv. It takes work so nice job.
Old 09-27-2011, 04:09 PM   #7
Military Mom of 4
Snav's Avatar
Ok - room is textured and painted (well, almost done being painted). I hate the yellow (my husband's color of choice) but whatever - I'm not the interior decorating type - that's all on him. I just do the work.
And as you can see I sculpted the center upward by removing the drywall in this area and evening it out with mud before adding the bead trim. So it's more 'flat' in appearance - not perfect, but much better - no serious sag illusion.
The arch looks better now that it's been tidied up and polished off.
Red bricked arch over front doors (leaking)! doityourselfno Building & Construction 7 06-04-2010 05:26 PM
red bricked arch over front doors (leaking) doityourselfno General DIY Discussions 1 05-30-2010 09:56 PM
Matching an arch JRiegler Carpentry 17 12-23-2009 07:07 AM
Basement arch height cobase Building & Construction 1 09-03-2008 07:20 PM
How do I frame an arch out of 2x4? murray59 Building & Construction 11 07-16-2007 07:33 AM
