Another One Under The Belt (almost) - Project Showcase - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 05:11 PM   #1
Another one under the belt (almost)
My upstairs Bathroom remodel is almost complete. I would have had the wainscoting done today, but the weather got nasty and I had to put the saws away. Anyway, here's a teaser....I will post more pictures when its all the way done.
1910NE is offline   Reply With Quote
Old 10-29-2010, 05:19 PM   #2
cocobolo's Avatar
Rewards Points: 5,952
That's looking pretty nice so far. What kind of wood are you using for the wainscoting?
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-29-2010, 09:02 PM   #3
I believe it's Baltic pine.
Old 10-29-2010, 09:06 PM   #4
cocobolo's Avatar
Thanks...it looked like some sort of pine, but it's often hard to tell from inside photos. The knots often give it away.
Is there any finish on the wood yet, or will you be doing that later?
Old 10-29-2010, 10:20 PM   #5
no finish yet. i was temped to stain it with a natural finish...but the boss said no. i will prime it with a good oil base to hide the knots and other imperfections, then sand and paint with white semi gloss.
Old 10-29-2010, 10:36 PM   #6
cocobolo's Avatar
Just a few minutes ago I sanded and filled a piece of cedar which I will use as trim above one of my doors.
I noticed that two knots were cracked, not uncommon with any knot. I use the DAP filler that goes on pink and dries white. It might be worth your while to do that.
It dries in nothing flat and sands just about instantly.
Old 10-29-2010, 11:10 PM   #7
jlhaslip's Avatar
Rewards Points: 2,096
shellac over the knots will stop any bleeding.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 10-29-2010, 11:21 PM   #8
cocobolo's Avatar
Yep, and I should have thought of that. Some woods don't bleed, like cedar. Some pines don't...pitch pine does...douglas fir does...hemlock doesn't...we could play this all night, couldn't we?
Baltic pine? I don't know. Maybe 191ONE can tell us...please. Is there any sign of pitch on your knots?
Old 10-30-2010, 03:06 PM   #9
no sign of pitch. there is a section of wainscoting that i put up a month or so ago, and primed with oil base (had to get it done before the radiator was re installed.) it shows no signs of knots bleeding through.....yet.
Old 10-30-2010, 03:54 PM   #10
cocobolo's Avatar
I think if it was going to bleed it would do it almost immediately. A month and no show, pretty sure you're OK.
Thanks very much for that.
Old 10-31-2010, 07:42 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 386
I agree a month should be plenty of time.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
GE Washer Belt Replacement lcortez Appliances 10 11-04-2009 07:02 AM
Belt care... RippySkippy Tools 3 12-25-2008 01:43 PM
Need held adjusting Craftsman Band Saw and Belt Sander tripower Tools 2 12-13-2008 08:23 AM
Dryer Belt KB Services Appliances 2 03-07-2008 12:35 PM
Snow blower drive belt replacement help lwhiten395 General DIY Discussions 5 01-15-2008 03:14 PM
