Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 06-19-2011, 03:39 PM   #1
Air conditioner
The external fan in my air conditioner stooped working this morning. Would it be the compressor?
Jeanguy12 is offline   Reply With Quote
Old 06-19-2011, 04:10 PM   #2
Missouri Bound's Avatar
Air conditioner
Nope. Either the fan itself has quit, you have a loose connection or perhaps the capacitor has gone bad. The compressor is seperate from the condensing fan.
Old 06-19-2011, 05:01 PM   #3
Air conditioner
Thanks Missouri Bound, I cooled the fan motor off. It started again. I did replace the fan motor a year ago with a generic motor; it worked perfectly all year last year. Guess the AC worked around the clock (it's hot in Tampa now) and the motor got overheated. This is an old unit.
Old 06-19-2011, 08:19 PM   #4
Air conditioner
Does that motor have a thermal overload? An air over motor generally doesn't have one. Consider ordering the correct motor for the unit.
Old 06-21-2011, 11:09 AM   #5
Coconut Pete's paella!
CoconutPete's Avatar
Air conditioner
Umm ... you may have better luck if you post this in the HVAC forum instead of the "product showcase".
CoconutPete is offline   Reply With Quote
Old 06-21-2011, 04:32 PM   #6
Air conditioner
That is unless you would like to show us your air conditioner....
Bring on the PICS!!
linuxrunner is offline   Reply With Quote
Old 06-22-2011, 07:01 AM   #7
Air conditioner
Well turns out the capacitor was bad. When I installed the generic fan motor a year ago I had to cut off a portion of the shaft to make it fit under the hood sort of speak. I used a reciprocal saw to do the job which may have shifted the bearings around a bit and created some sort of electrical distortion according to Joe, an electrical whiz at Grainger. His recommendation for the future was to power up the motor so the shaft would be turning and then applying the cutting blade to the shaft thereby avoiding messing up the works inside the motor.
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 11:29 AM
Zenith Air Conditioner chrisatola HVAC 5 06-29-2010 09:07 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 07:07 PM
Novel Way to increase effeciency of portable Air conditioner Tell me what you think macmini HVAC 5 05-25-2009 06:58 AM
Installing window air conditioner mary60 Electrical 1 08-14-2008 07:25 PM
