Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 06-12-2012, 10:55 AM   #46
6 weeks to an outdoor fireplace, here we go...
Nice work
pwgsx is offline   Reply With Quote
Old 06-14-2012, 05:29 PM   #47
Laid out the pattern on the arch form...
Doing things almost the right way...
Double is offline   Reply With Quote
Old 06-15-2012, 08:50 AM   #48
Arch is set and the toppers for the side fireboxes are set as well. I ended up using angle iron to support the front edge of the side boxes. This arch is the second attempt; for the first try I tried to remove the form immediately after while the mortar was still maleable. I read on a couple structural masonry sites that this would help to make a stronger bonder across the arch. Maybe this is practical for a master mason, but I failed horribly and knocked a couple bricks loose taking the form down, which caused total arch collapse. Hoping that a day or two to cure will give the strength required.
Old 06-17-2012, 10:11 PM   #49
Concrete & Masonry
Two things:
- I just noticed something that looks strange in picture #2 of post #46. You'll need to cap those open cores off of the block behind the firebrick. I've always shifted the smoke chamber to the front to create the ledge/shelf at the front, as I think it just generally performs better and smokes less out the face. Honestly, not as big of a deal on an outdoor FP, but you certainly don't want to leave those block open in that situation......
- I would lay the arch, as well as a few courses above it, allow it to set at least overnight, and you shouldn't have any issue. It's probably too late, but I would recommend minimizing the amount of mortar you use on the bottom side of the arch brick, as you can't tool the joints the next day when they're set. It's easier to simply fill & tool the missing joints the next day rather than chip/grind out the mortar and them have to fill and tool anyways.
Otherwise, keep up the good work.........
jomama45 is offline   Reply With Quote
Old 06-17-2012, 10:34 PM   #50
Two good points...
Those openings were all capped right after that picture so I've got that one knocked out.
Arch worked very well when I let it set up overnight, and I did exactly what you noted and simply used a little less mortar than normal and pointed it later.
Todays progress...got the pattern inset above the arch, laid some of the mantel, filled in brick to the mantel level, hope to finish it up tomorrow except for some detail work around the inset pattern and some pointing
6 weeks to an outdoor fireplace, here we go...-forumrunner_20120617_213101.jpg
Old 06-20-2012, 09:03 AM   #51
More progress, in the home stretch now, hope to finish it up tonight/tomorrow night...
Old 06-20-2012, 09:39 AM   #52
Taking into account location = Texas
Taking into account the month = June
Taking into account the weather = Hot
And outdoor fireplace gets priority over a pergola.
All I can say is ??????????????????
To each their own. And enjoy as it does look nice.
hammerlane is offline   Reply With Quote
Old 06-20-2012, 10:58 AM   #53
Im sure he wants to finish it before the fall. Nothing like starting a project and moving on to another just bc its "HOT".
Looks good man, I wish I had made my own fire box instead of the drop in I used but I was in a hurry. Nice job!!!
Old 06-20-2012, 11:58 AM   #54
Sephora's Avatar
Looks great!!!
Sephora is offline   Reply With Quote
Old 06-21-2012, 09:21 AM   #55
Got the last firebrick laid last night, and I'm almost up to the chimney cap, how about votes on the top pattern?
I like some of these...
Name:  crazy chimney.jpg
but a little to dramatic maybe.
Im thinking a single row of brick end hanging out, topped with a single surround of 3/4 vertical brick, sort of a combo of these two here...
This second picture illustrates the idea, but there would be no more rows above the vertical row...
And of course there will be no real "cap" on the top, it will be fully open
Thoughts?
Old 06-21-2012, 11:35 AM   #56
i like the knot pic, think you can pull that off? I would just do the second to last pic, simple and looks nice. Are you doing a metal wind cap? You may get downdrafts depending on the wind direction when you have your fire.
Old 06-21-2012, 11:46 AM   #57
I wasn't planning on doing anything on the top, but that being said, it is often VERY windy here, so maybe it is something to consider.
Old 06-22-2012, 08:29 AM   #58
Getting dark to early even with my headlight on...didn't quite get everything finished, maybe this evening, but pretty close. Just need to trim out around the firebox and pattern detail, and lay the chimney detail row, then time for fire...
6 weeks to an outdoor fireplace, here we go...-forumrunner_20120622_072854.jpg
Old 06-25-2012, 08:18 AM   #59
Finished, first fire last night!
6 weeks to an outdoor fireplace, here we go...-forumrunner_20120625_071828.jpg
Old 06-25-2012, 09:13 AM   #60
Custom User Title
Looks great, but talk about a wimpy fire! :p
no1hustler is offline   Reply With Quote
Post action review of my last 2 weeks off work WillK Building & Construction 1 01-02-2012 11:54 PM
Dutch boy -still tacky 6 weeks thburd Painting 3 08-07-2011 10:56 AM
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General Discussion 24 05-19-2011 08:23 PM
pilot light goes out about every 3 weeks james-york Plumbing 0 04-05-2011 10:27 AM
New tyle grout 2 weeks old is too low between tiles jlburdge Tiling, ceramics, marble 4 03-15-2011 08:29 AM
