22x22 Addition: Basement workshop, master bedroom above.
Current house is 37x20 ranch/cottage on a 6'8" basement.
Addition will be 22x22 set back 8" from front of house extending 2'8" into back yard. Basement of the addition will be 8'8" high (for the most part) with two 4" lolly columns 7' high that a 3'6" wide hallway will rest on.
Basement will be a workshop with a small corner boxed out for a music/instrument room. Main floor will be a master bedroom and bath. Main floor will be heated via radiant heat and a direct/tankless system. Basement will not be heated intill the permit is closed with a C.O.. ( gotta love taxs)
As far as laborers go, aside from the excavator and mason, it will be myself with the help of a friend or two when the time comes to do heavy/awkward lifting and then i will hire a roofer to shingle and when the time comes a taper to mud the sheet-rock.
The floor joists will be TGI's 11 7/8 12oc for the most part and 16oc where it can be. To install the joists i plan on renting one of them "plate form jack/lifts" which some people use for installing sheet-rock on ceilings. Gonna slide the joist over the front wall onto the lift, wheel it to place then set and nail (we'll see how that goes), hope to do the same for the LVL's (1-7/8x11-7/8) if not a friend will help.
The roof will be trusses, did not want any load bearing walls on the inside (wanted to leave the floor plan open to change and not have to head back to the architect if i wanted to make changes (even though she was a wonderful person, helped me out alot).) The building inspector is great (at least for me). Already made alittle change to the stairs in the addition and he has no problem with that.
Well guess its time for pictures
Heres a link to an online album i started so a relative from afar can see whats being done...
http://photos.joescove.com/index.php?cat=3
As of now the basement walls are poured and the excavator will be here tomorrow to fill the gravel for the slab. Will update the pictures later tomorrow night after all that is done.
