2012 - Basement demo
I wanted to make this opening bigger, so I put the studs closer to the metal support post. The issue is now the right side. Since there will be a wall coming right off that corner, will it look bad to leave it how I have it?
Or should I throw in another stud on the right, maybe 3-4 inches in? That way there will be a patch of drywall going up the right side of the wall.
Or can I move the 2x4 on the right flush with that bottom plate. This way the wall can continue to go back?
Basement Demo started Jan 2012: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Bathroom demo started Feb 2013: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
