2012 - Basement Demo - Project Showcase - Page 7 - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 07:22 PM   #91
Trucon01's Avatar
Rewards Points: 510
Unexpected project... Never knew the top floor bathroom fans were not vented to the outside. So.....
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 08-22-2012, 09:34 PM   #92
shadytrake's Avatar
Rewards Points: 364
Looks like you have your hands full. Looking good.
shadytrake is offline   Reply With Quote
Old 08-23-2012, 05:34 PM   #93
Rewards Points: 610
Run your sprinkler and go and look at the water lines in the basement. One of them may have a crack/split/leak that only shows up when running the outside tap. It happened to me once.
techpappy is offline   Reply With Quote
Old 08-23-2012, 05:47 PM   #94
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
That's a good point. Happened to me this year but it was much worse. Water splashing a few feet away from my server rack was a little unnerving.
Old 08-23-2012, 06:07 PM   #95
Trucon01's Avatar
Rewards Points: 510
Unfortunately, the water on the wall is on the complete opposite side of where the outside faucet is. The water lines in those pictures are for the bathroom right above.
After I moved the sprinkler, the water issue stopped. I then noticed vent holes in the brick in that location. Maybe I was getting water directly in the vent hole and down the foundation
Old 08-25-2012, 07:43 AM   #96
Trucon01's Avatar
Rewards Points: 510
I need opinions on something...
After I put in the weeping tile and I'm ready to re-concrete the floor, is it a good idea to place the 2in XPS foam board on the wall and slide it down, under where the slab WOULD be? Once the foam is in place, I would concrete around it so any water coming through the wall would filter down behind the board into the drain?
Yay or nay?
Old 08-25-2012, 12:34 PM   #97
Rewards Points: 610
If you still get water through the wall that means your drainage is inadequate and you may have to dig along the outside wall and put in proper weeping drainage system including waterproof membrane on exterior of the wall. But, what you are suggesting probably wouldn't hurt.
Suggest you google DIY network or Holmes on Holmes and try to find his program where he has addressed this type of issue. I'm not sure but I think he attached a dimpled membrane on the inside of the basement wall to help with this situation.
Old 08-25-2012, 03:00 PM   #98
Trucon01's Avatar
Rewards Points: 510
After a few hours of digging. We exposed the cast iron toilet and shower drain...
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo.jpg   2012 - Basement demo-photo-2.jpg
Old 09-07-2012, 02:10 PM   #99
nice progress, can't wait to do this at my house
coop26 is offline   Reply With Quote
Old 09-13-2012, 09:53 AM   #100
Trucon01's Avatar
Rewards Points: 510
Help with proper interior drain tile.
From the image, is this the proper way of installing the drain tile system? Including adding weep holes above the pipe? If not, please let me know where they should go or if they should be there at all.
Also, if anything else is out of place, of course, please let me know.
Old 09-16-2012, 05:25 PM   #101
Trucon01's Avatar
Rewards Points: 510
I'm removing the back wall sump pit because it never did anything anyway. I will be filling it with dirt, rock and then cementing over it. However, right in that corner, it dips down (as seen in the pictures).
My question is, what is the best way to handle the dip? Do just cement the sump pit, wait for it to dry and then throw down some leveling cement?
OR
Do I just jackhammer up that small section and just cement everything all over, properly?
Thanks.
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-4.jpg
Old 09-16-2012, 06:23 PM   #102
I'd cement it as best you can then use leveling compound.
rebelranger is offline   Reply With Quote
Old 09-16-2012, 06:41 PM   #103
Rewards Points: 610
If you need it level I would fill with dirt etc, with well packed sand and smack down with sledge hammer until your arms wear out .must ...then use self leveling to finish off.. BUT I'm not a cement head!! lol...is that what they call you guys?
Old 09-16-2012, 07:06 PM   #104
Trucon01's Avatar
Rewards Points: 510
Thanks guys... If I do use the leveling cement, will it withstand nails being shot into it? I plan on framing over it...
Old 09-16-2012, 07:41 PM   #105
Yes as long as it gets a good bond with the concrete below, IE make sure the surface is prepped before pouring the self leveler.
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 06:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
