Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 07-13-2012, 11:30 AM   #76
Trucon01's Avatar
2012 - Basement demo
Yard graded and re-sodded!!! YAY!
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 07-16-2012, 12:54 PM   #77
Trucon01's Avatar
The saga continues with my water issue...
This water is coming in from me watering the yard at 5:30 until 6:35am (on a timer).
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-4.jpg
Old 07-16-2012, 01:31 PM   #78
Wire Chewer
Red Squirrel's Avatar
Is the part where the leak starts above ground by chance? I have the same issue, I think it has to do with the brick vent holes. Water gets into that and it gets into the block. You're apparently not suppose to block those vents, but I've been contemplating it or at least add some kind of cover that wont let water in. While it's not often that rain hits at an angle enough to get into those vents, it can still happen.
Old 07-17-2012, 02:00 PM   #79
Trucon01's Avatar
Where the water starts on the wall is below ground, barely maybe less than a foot down. Remember, I dug down and patched that crack outside with cement and a rubber membrane. I'm assuming the water is getting in from the brick above ground where the sprinkler is hitting. I may have to look for more cracks...
We've had a few hard rains, prior to me watering the grass and water does not show up...
Old 07-17-2012, 02:37 PM   #80
Wire Chewer
Yeah my guess is the water is coming up from higher up, and it just happens to only show up below ground. Is that wall the one you posted a pic of with the grass redone? I see a vent, wonder if it's getting in through there somehow.
Old 07-17-2012, 02:41 PM   #81
Trucon01's Avatar
Yes, it is the wall with the white vent. The vent was for a bathroom ceiling fan. That vent goes through the rim joist, which is 1 joist to the right of where the water is coming in (so its not directly above the water penetration).
Old 07-17-2012, 09:25 PM   #82
Trucon01's Avatar
Here is a picture of the inside wall where the water is coming in from the sprinkler...
Old 07-17-2012, 09:27 PM   #83
Trucon01's Avatar
I also broke out all the framing around the electrical panel.
Question for anyone. How much of a pain in the a$$ is it to move the panel to the wall on the left? I doubt the wires on the right side of the main line in are long enough to reach...
2012 - Basement demo-photo-1-1-.jpg   2012 - Basement demo-photo-2-1-.jpg   2012 - Basement demo-photo-3-1-.jpg   2012 - Basement demo-photo-4.jpg
Old 07-28-2012, 04:28 PM   #84
Trucon01's Avatar
Digging up the basement floor to re-do the plumbing for the full bath, plus putting in a weeping tile system. Enjoy the pics.
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-4.jpg   2012 - Basement demo-photo-5.jpg
Old 07-28-2012, 04:29 PM   #85
Trucon01's Avatar
More Pics
2012 - Basement demo-photo-1-1-.jpg   2012 - Basement demo-photo-2-1-.jpg   2012 - Basement demo-photo-3-1-.jpg   2012 - Basement demo-photo-4-1-.jpg   2012 - Basement demo-photo-5-1-.jpg
Old 07-28-2012, 04:30 PM   #86
Trucon01's Avatar
More Pics.
2012 - Basement demo-photo-1-2-.jpg   2012 - Basement demo-photo-2-2-.jpg   2012 - Basement demo-photo-3-2-.jpg
Old 08-01-2012, 09:27 PM   #87
Trucon01's Avatar
Does everything have to be a chore??? I'm 3 feet down under the slab and I'm still not to the footer... Does anyone know how far down a typical footer is?
Old 08-02-2012, 11:12 AM   #88
Moving your Elect panel won't be cheap. You'll have to get the utility co to come move the main line, unless you have a outside shutoff. Then you'll have to rewire all your connections. Just think about it.
Why are you going so deep on your bath concrete. I only went 12" down to install new PVC for a shower, then gravel and concrete.
rebelranger is offline   Reply With Quote
Old 08-02-2012, 11:12 AM   #89
Oh AWESOME WORK! keep going
Old 08-02-2012, 12:36 PM   #90
Trucon01's Avatar
I wanted to put a weeping tile along the whole front side of the basement floor..
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 07:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
