Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 02-25-2012, 07:48 PM   #31
Trucon01's Avatar
2012 - Basement demo
A few more pictures showing the front of the basement. Each of our well windows has not officially leaked. Can't wait to rip those out as well...
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-4.jpg
Trucon01 is offline   Reply With Quote
Old 02-25-2012, 07:50 PM   #32
Trucon01's Avatar
Can anyone tell me what type of rodent does this to wood? (last 2 pictures). When I took down the ceiling drywall, there was a ton of droppings, within that section of drywall, between the joists...
2012 - Basement demo-photo-1-1-.jpg   2012 - Basement demo-photo-2-1-.jpg   2012 - Basement demo-photo-3-1-.jpg   2012 - Basement demo-photo-4-1-.jpg
Old 03-02-2012, 10:49 PM   #33
No egress windows? Sounds like a death trap to me.
bkeech is offline   Reply With Quote
The Following User Says Thank You to bkeech For This Useful Post:
Ravenworks (05-05-2012)
Old 03-06-2012, 11:38 AM   #34
Trucon01's Avatar
Yea, after reading in here, I would have loved to do that in the back of the house, but I had a stamped concrete patio poured in the entire yard, up to the foundation... The only other window is the very front of the house. Is it smart have an egress window in the front of the house?? If I can get some opinions, I may just do that instead...
Thanks for bringing that up!
Old 03-07-2012, 01:08 PM   #35
I believe egress windows should be located in all bedrooms and living areas. Do you have a permit?
Old 03-27-2012, 11:05 AM   #36
Any progress?
It sounds like he's just making one large living space. Would he still need an egress window?
mikegp is offline   Reply With Quote
Old 03-27-2012, 11:40 AM   #37
Jack of all - master none
hyunelan2's Avatar
I always thought the rule of thumb was you needed "two ways out" of any living space?
hyunelan2 is offline   Reply With Quote
Old 03-29-2012, 12:17 AM   #38
Moderator
Basements require an egress window/door in addition to, the stairs up to the egress (usually front) door. If a bedroom is in the basement, that (bedroom) requires egress and will cancel the basement egress.
"R310.1 Emergency escape and rescue required.
Basements,
habitable attics and every sleeping room shall have at least one operable emergency escape and rescue opening. Where basements contain one or more sleeping rooms, emergency egress and rescue openings shall be required in each sleeping room. Where emergency escape and rescue openings are provided they shall have a sill height of not more than 44 inches (1118 mm) measured from the finished floor to the bottom of the clear opening. Where a door opening having a threshold below the adjacent ground elevation serves as an emergency escape and rescue opening and is provided with a bulkhead enclosure, the bulkhead enclosure shall comply with Section R310.3. The net clear opening dimensions required by this section shall be obtained by the normal operation of the emergency escape and rescue opening from the inside. Emergency escape and rescue openings with a finished sill height below the adjacent ground elevation shall be provided with a window well in accordance with Section R310.2. Emergency escape and rescue openings shall open directly into a public way, or to a yard or court that opens to a public way." From: http://publicecodes.citation.com/ico...2_3_sec010.htm
Minimum size egress window: https://docs.google.com/viewer?a=v&q...33otStRi7Aff7g
Better to get a permit for the paper trail for your H.O. Insurance carrier and not get hit when time to sell. May require removing all your basement work to close the sale and a possible fine. Saying nothing of a fireman with an oxygen tank on not able to rescue someone down there ....
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
jagrrr (11-08-2012), kwikfishron (05-04-2012)
Old 05-04-2012, 07:46 AM   #39
Trucon01's Avatar
So its been a while since I updated you with pictures. All I have done recently is try to tear down the bathroom which is the last standing room in the basement.
And what do I find? A bunch of mold growing on the concrete block in the corner... I have a waterproofing company coming Monday to give me a free foundation inspection, so we shall see...
Old 05-04-2012, 07:51 AM   #40
Trucon01's Avatar
Just a few more pictures of what I did last night until 8pm... I have since cleaned both the full front wall and full back wall with a straight bleach spray and scrubbed using a hard bristle brush. The mold on the walls are pretty much gone.
Also, I took up the tile in the bathroom. WHAT A PAIN IN THE A$$!!!
The last picture shows where I cut out the copper pipe from the shower and capped it with 2 shark bite ball valves. First time I ever used them and they are great! I have to admit, I was afraid to turn the water back on with them on, but they are holding...
2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-5.jpg   2012 - Basement demo-photo-4.jpg
Old 05-05-2012, 09:22 PM   #41
Trucon01's Avatar
A fridays night work in the basement...
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-4.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg
Old 05-05-2012, 09:24 PM   #42
Trucon01's Avatar
I can't believe how much more garbage I'm taking out. My floor was clean and swept, now it looks like this again...
I also spray foamed the bottom of the sill plate at the front and back of the house.
Clean up starts tomorrow and I'll keep you posted.
2012 - Basement demo-photo-5.jpg   2012 - Basement demo-photo-3-1-.jpg   2012 - Basement demo-photo-2-1-.jpg   2012 - Basement demo-photo-1-1-.jpg
Old 05-14-2012, 01:27 PM   #43
Trucon01's Avatar
Starting the rim joist insulation. Purchased a 2in x 4ft x 8 ft piece of XPS foamboard from Lowes for 30.00 and cutting to fit. Prior to inserting foam, all 4 sides of the rim joist were caulked. One day at a time....
Old 05-14-2012, 02:50 PM   #44
Great pictures, looks like you're getting it cleaned up pretty well, I've got a similar project coming up on my part in the next 6 months or so, not looking forward to the clean up.
mike2 is offline   Reply With Quote
Old 05-14-2012, 03:44 PM   #45
Trucon01's Avatar
Quick question for the crowd... Whats the best way for me to break up the concrete where the bathroom was? Jackhammer or rotary hammer? I need to dig up the floor as well as knock down the lip that was created.
Thanks Mike. Yea, its a royal pain in the a$$. I've taken probably over 2-3 tons of garbage out of the basement (wood, drywall, etc) over the past few months. But I've learned so much doing it on my own, watching video tuts and listening to the guys on here. For the pros to take the time and give free advise means a lot to me and I know means a lot to everyone on here.
If you have any questions about my specific project or want pictures of anything else, please let me know.
PS -- All my photos were taken with my iPhone 4s.
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 07:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
