2012 - Basement Demo - Project Showcase - Page 17 - DIY Chatroom Home Improvement Forum
Old 03-10-2014, 06:34 AM   #241
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
Looking good.
That toy will pay for itself 1000X over by saving you back problems and visits to the doctor.
Old 03-10-2014, 08:35 AM   #242
Rewards Points: 1,426
Plus you can probably sell it when you're done for the same amount you paid for it.
That was my plan, but now I think I'm going to keep it. You never know when you might have to tear down a ceiling.
mikegp is offline   Reply With Quote
Old 03-10-2014, 02:43 PM   #243
Trucon01's Avatar
Rewards Points: 510
Ill def be keeping it. It folds up quite nicely! My dad is happy, thats for sure
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 03-11-2014, 05:42 PM   #244
Rewards Points: 14
Originally Posted by Trucon01 View Post
Hi Derek!
Are you referring to the shanks they used to secure the firring strips to the block wall? If so, I use a long crowbar.
Thanks Jeff,
Yes those, and were there any cements nails or archors holding the bottom plates to the cement floor? It is hard to tell from the first couple of pictures but it looks like there were bottom plates
Thanks,
Derek
shavlor is offline   Reply With Quote
Old 03-11-2014, 05:47 PM   #245
Trucon01's Avatar
Rewards Points: 510
Originally Posted by shavlor View Post
Thanks Jeff,
Thanks,
Derek
They didn't have any bottom plates. All there was were firring strips nailed to the wall with paneling staples to it. The bottom was then covered with a baseboard.
Since there were no bottom plates, all the electrical outlets were recessed into the block wall...
Old 03-11-2014, 06:15 PM   #246
Rewards Points: 14
Interesting, unfortunately my basement had/has bottom plates that need replacing, both nails and bolts. I am using crow bar to break them since they are not coming up all the way, probably will have to grind them down then cover with finishing cement.
Nice lift, I got one before I knew that would need to reframe... now it is waiting in its box
Old 03-11-2014, 06:28 PM   #247
Trucon01's Avatar
Rewards Points: 510
Drywall starting...
2012 - Basement demo-image-2617370394.jpg   2012 - Basement demo-image-1388727193.jpg
The Following User Says Thank You to Trucon01 For This Useful Post:
Windows on Wash (03-12-2014)
Old 03-13-2014, 02:35 PM   #248
Rewards Points: 91
Trucon, looks amazing man. Nice progress. I just went through every page and I like it. I had to redo about half of my basement when we first bought it and am in the works of starting to finish the rest (wish I just would have done what you did but didn't have the time...needed half of it finished right away for the new daycare). I just have a couple of questions...
1. Why did you decide not to put foamboard on every outside wall?
2. Is there a reason you put your bathroom at the bottom of the stairs instead of across the room? This would have opened up the bottom of the stairs a little.
3. I noticed a few pages back, your pic of your new panel. I know you said your panel passed inspection but are you allowed to frame in around your panel?
4. Somebody had mentioned about putting weatherstripping around the doors to your utility closet so I am assuming that your HVAC and everything are electrical?
Just some thoughts I had while looking through. Either way, doing a great job! I look forward to the finished project...
nvycrmn is offline   Reply With Quote
Old 03-13-2014, 09:57 PM   #249
I'm guessing that block wall is a separating wall from the neighbor's basement.
As far as weather stripping around the mech room door, my heat and furnace have intakes that go to the outside.
Old 03-13-2014, 10:05 PM   #250
Rewards Points: 91
that makes sense about the block wall...forgot how close the neighbors were!
As for the door, my furnace and water heater are both gas. While they are vented through the roof, I was told that I need to make sure that both have enough air to "breathe" because of the combustion...
Old 03-14-2014, 07:53 AM   #251
Mine are gas as well, but they have an exhaust and an intake that go through the top of the foundation to get outside air. Some units just pull air from the room so people put louvered doors or leave a gap somewhere. I'd just be afraid of co poisoning in that situation if anything ever goes wrong.
Old 03-14-2014, 10:06 AM   #252
Trucon01's Avatar
Rewards Points: 510
Thank you and thanks for taking the time to read!
To answer your questions:
1. I have an inside townshouse so those walls are shared with neighbors.
2. There was already a bathroom down there in that location. So there was a cast iron pipe under the slab as well as an exhaust vent already drilled into the brick. So I kept the location and replaced the cast iron with PVC, etc.
3. Not sure, and I haven't decided if I'm framing to the outside of the box or making a larger door so you can get to the grommets.
4. Yes, everything is electric.
Thanks again and feel free to ask any other questions.
Jeff
Old 03-14-2014, 10:15 AM   #253
Trucon01's Avatar
Rewards Points: 510
Ceiling is up in the back part of the basement. Replaced both front and back faucets. And... Build the shower pan. Not hard to do, but a pain in the a$$.
2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-4.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-5.jpg
Old 03-14-2014, 10:17 AM   #254
Trucon01's Avatar
Rewards Points: 510
Hit yourself with a hammer... Check
Cut yourself with a box cutter... Check
Old 03-14-2014, 10:35 AM   #255
Did you by chance have a small break on the top of the drywall so pulled out some compound to fix it a little and then used left over to cover some screw holes? I only ask because I did that exact same thing when I first started my drywall.
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 07:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
