2012 - Basement Demo - Project Showcase - Page 16 - DIY Chatroom Home Improvement Forum
Old 02-15-2014, 06:30 PM   #226
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,206
Sweet.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 02-16-2014, 10:18 AM   #227
Trucon01's Avatar
Rewards Points: 510
Changed out the 3" abs with 3" pvc. 2 furncos and a 2 way cleanout.
2012 - Basement demo-image-2620899783.jpg   2012 - Basement demo-image-3342110581.jpg   2012 - Basement demo-image-354311420.jpg
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 02-16-2014, 04:03 PM   #228
Trucon01's Avatar
Rewards Points: 510
Updated electrical panel...
Old 02-17-2014, 05:45 PM   #229
Trucon01's Avatar
Rewards Points: 510
Dont forget to change out your filters!
Old 02-25-2014, 03:09 PM   #230
Trucon01's Avatar
Rewards Points: 510
Starting to lay out the bathroom to see how it may look... Thinking about going with a curbless linear drain for the shower. Thoughts on that?
Also, any tricks for putting a door on an angle?
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg
Old 03-01-2014, 02:46 PM   #231
Trucon01's Avatar
Rewards Points: 510
Have the layout all done. Just need to throw in some studs!
Old 03-04-2014, 10:16 AM   #232
Rewards Points: 14
Hello Jeff,
Thanks for making this thread. It is very useful and glad to see that you are making process.
If you have time I have a quick question for you.
How did you remove the old cement archors from the previous framing?
Thanks,
Derek
shavlor is offline   Reply With Quote
Old 03-06-2014, 10:18 PM   #233
Trucon01's Avatar
Rewards Points: 510
Originally Posted by shavlor View Post
Hello Jeff,
Thanks,
Derek
Hi Derek!
Are you referring to the shanks they used to secure the firring strips to the block wall? If so, I use a long crowbar.
Old 03-07-2014, 09:18 AM   #234
Trucon01's Avatar
Rewards Points: 510
Finished more framing and added a few more lights.
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-4.jpg
Old 03-07-2014, 09:22 AM   #235
Rewards Points: 1,456
Did you tear down that ceiling just to put in the light?
mikegp is offline   Reply With Quote
Old 03-07-2014, 09:28 AM   #236
Trucon01's Avatar
Rewards Points: 510
No, all of this drywall is coming down anyway, I'm in the middle of wiring up a 3-way and this light will be part of it. So I had to knock down this ceiling and the wall to the right (which you can kind of see) for the new switch.
The original lights were contractor grade and powered by a set of outlets from the middle floor (different circuit). So I'm changing all that now.
Old 03-07-2014, 09:00 PM   #237
Trucon01's Avatar
Rewards Points: 510
More pictures.
1-2. Storage room with 2 5" lights
3. 20A dedicated GFCI TR oulet and location of sink and toilet.
4. Shower base (not done yet, started to add in 2x10 backers for pan).
5. Side shower wall, where a shower niche will be added in the middle (not yet framed).
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-4.jpg   2012 - Basement demo-photo-5.jpg
Old 03-07-2014, 09:03 PM   #238
Trucon01's Avatar
Rewards Points: 510
Special thanks to Hammerlane for helping me with the 3-way switch!
1. 1-3 of 4 lights on 3-way switch (top and bottom of stairs)
2. Looking down from a few steps up.
3. Last of the 4 lights on the 3 way.
4. Switch at the top of the stairs leading to the basement.
All drywall will be coming down in the stairwell, leaving it up until I get all the drywall in so I don't chip the edges.
2012 - Basement demo-photo-1-1-.jpg   2012 - Basement demo-photo-2-1-.jpg   2012 - Basement demo-photo-3-1-.jpg   2012 - Basement demo-photo-4-1-.jpg
Old 03-09-2014, 11:40 AM   #239
Trucon01's Avatar
Rewards Points: 510
Slc in bathroom floor. Shower niche framed with bottom pitched in. 2x10 backer for pan. 130 cfm fan. Framed out hvac box.
Enjoy!
2012 - Basement demo-image-1948758651.jpg   2012 - Basement demo-image-3517303953.jpg   2012 - Basement demo-image-3875573966.jpg   2012 - Basement demo-image-403906539.jpg   2012 - Basement demo-image-214914254.jpg
Old 03-09-2014, 01:56 PM   #240
Trucon01's Avatar
Rewards Points: 510
New toy
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 06:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
