2012 - Basement Demo - Project Showcase - Page 14 - DIY Chatroom Home Improvement Forum
Old 02-09-2013, 06:03 PM   #196
Originally Posted by Trucon01 View Post
During the day, we got up the XPS foam on the front wall.
Looks like you used some type of adhesive with the XPS foam? Any reason you didn't go with screws and plates? (I'm slowly adding foam board to my basement, but I've been using screws and plates..)
Keep up the good work!
Adrenalinejunky is offline   Reply With Quote
Old 02-09-2013, 06:44 PM   #197
Trucon01's Avatar
Rewards Points: 510
Yea, I used PL-300 Foamboard adhesive. I didn't want to put any screws through the concrete block walls, I was more comfortable with the dabs of PL-300. It worked really well for the back wall.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
The Following User Says Thank You to Trucon01 For This Useful Post:
Adrenalinejunky (02-18-2013)
Old 02-16-2013, 12:45 PM   #198
Trucon01's Avatar
Rewards Points: 510
Concrete over the french drain...
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-4.jpg   2012 - Basement demo-photo-5.jpg
Old 02-16-2013, 12:46 PM   #199
Trucon01's Avatar
Rewards Points: 510
More pics
2012 - Basement demo-photo-1-1-.jpg   2012 - Basement demo-photo-2-1-.jpg   2012 - Basement demo-photo-3-1-.jpg
Old 06-09-2013, 12:33 AM   #200
That looks like roaches to me.
GinaMarie is offline   Reply With Quote
Old 06-09-2013, 01:03 AM   #201
I love the outside of your house with the arched windows. It looks like a little Brooklyn Brownstone!
Old 12-07-2013, 10:27 AM   #202
Trucon01's Avatar
Rewards Points: 510
I'M BACK!!! After a bathroom re-do and work, I'm not back in the basement and re-energized. Enjoy
Some concrete and some wire organizing...
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-5.jpg
Old 12-07-2013, 10:28 AM   #203
Trucon01's Avatar
Rewards Points: 510
Here is most of the middle room being framed and wired.
2012 - Basement demo-photo-3-1-.jpg   2012 - Basement demo-photo-4-1-.jpg   2012 - Basement demo-photo-5-1-.jpg
Old 12-07-2013, 10:31 AM   #204
Trucon01's Avatar
Rewards Points: 510
Now for the full basement plumbing...
Most supplies are from PexSupply (AquaPex with expansion fittings / tool)
Water pressure = 92PSI!!! So I picked up a PRV.
2012 - Basement demo-photo-1-1-.jpg   2012 - Basement demo-photo-1-2-.jpg   2012 - Basement demo-photo-2-1-.jpg   2012 - Basement demo-photo-2-2-.jpg   2012 - Basement demo-photo-3-2-.jpg
Old 12-27-2013, 02:36 PM   #205
Trucon01's Avatar
Rewards Points: 510
Prepping the tank and sillcocks. Thanks to TheEPlumber in the Plumbing section.
Old 01-05-2014, 02:44 PM   #206
Trucon01's Avatar
Rewards Points: 510
Working on more framing...
Old 01-05-2014, 10:00 PM   #207
Trucon01's Avatar
Rewards Points: 510
Ran all new 10-3 wire for the water heater and dryer and 12-2 for the washer. Also put up the washing machine box.
Washer and Dryer outlets are stacked because I will be getting a new washer and dry and stacking them to make more room in the laundry.
Plywood will be where I mount the 5g expansion tank as well as my hot / cold manifolds.
Old 01-18-2014, 07:29 PM   #208
Trucon01's Avatar
Rewards Points: 510
What a day... We successfully installed the water heater and all new AquaPex in the basement to the entire house. Pressure valve and Expansion tank also installed. Water pressure is now down from 92 to 70.
Using the expansion tool was extremely easy. The tool is expensive but well worth a buy, use and sell on ebay.
Old 02-01-2014, 09:31 PM   #209
Trucon01's Avatar
Rewards Points: 510
The first 2 pictures are of a duct box I had to re-build to get ac/heat to an upstairs half bath.
The rest of the pictures are more framing. Pic 3-4 are of a closet. One side for the general basement the other side will be for the laundry room.
Pic 5 will be of a small build in nook. Around 20x48.
Lastly, we took all the copper pipes, 50g hot water tank and a old laly column to the scrap yard. Got $205 for everything...
Old 02-02-2014, 07:58 AM   #210
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Looking good hommie.
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 06:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
