Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 01-19-2013, 08:36 PM   #181
Trucon01's Avatar
2012 - Basement demo
Sick of carrying a light into the attic with me so I put a light, a switch and an outlet.
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 01-19-2013, 08:43 PM   #182
Trucon01's Avatar
After about 2 hours, cutting holes in the drywall, I finally got 2 12-2 cables from the basement, up 2 floors and into the attic!!! Pictures are in order from basement, floor 1, floor 2 then attic.
2012 - Basement demo-photo-1-2-.jpg   2012 - Basement demo-photo-4-1-.jpg   2012 - Basement demo-photo-5-1-.jpg   2012 - Basement demo-photo-5.jpg   2012 - Basement demo-photo-3-1-.jpg
Old 01-19-2013, 08:47 PM   #183
Trucon01's Avatar
Also removed the case iron pipe and picked up all new PVC, which I will get to tomorrow.
I used a Ryobi grinder ($39.97) from HD to get through the cast iron pipe. All tool rental places close around noon here on Saturdays!!!
2012 - Basement demo-photo-4.jpg   2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg
Old 01-20-2013, 02:07 AM   #184
good stuff!
how did you connect the wire to the panel?
edit; are you on 200amps?
federer is offline   Reply With Quote
Old 01-20-2013, 08:33 AM   #185
Trucon01's Avatar
I didn't connect the wires to the panel yet. It was getting late last night and my goal was just to get 2 12-2 wires into the attic. I'll probably get the wires to the bathrooms and hooked up in the panel on Monday. Today I'll be installing the french drain and dry fitting the 4" PVC for the toilet and shower.
Yes, I am on 200 amps and just had my panel replaced with all Square D QO equipment.
Old 01-20-2013, 07:14 PM   #186
Trucon01's Avatar
Got rid of the 15a GFCI in one bathroom and replaced it with a dedicated 20A GFCI on 12-2.
HD closed at 7 tonight and I need a few grommets to put the wire in the electrical panel...
2012 - Basement demo-photo-4-2-.jpg   2012 - Basement demo-photo-2-2-.jpg   2012 - Basement demo-photo-3-2-.jpg
Old 01-20-2013, 07:16 PM   #187
Trucon01's Avatar
Started to lay the french drain...
Old 01-21-2013, 10:40 AM   #188
I just spent the last hour reading all your 13 pages worth, very informative. Keep up the great work and keep us informed.
Last year i bought my first dwelling, small 750 sq feet condo and started doing some small renovations, nothing quite like this!!.
Thumbs up!
laflsyl10 is offline   Reply With Quote
Old 01-22-2013, 10:06 AM   #189
Trucon01's Avatar
Thanks a lot for reading!!
Good luck with your work and let me know if you have any questions or want pictures of anything I'm working on or have worked on.
Jeff
Old 01-23-2013, 07:28 AM   #190
Trucon01's Avatar
I finished installing the 20A circuit to the last bathroom last night. I had to cut a bigger hole because this box was fed from the bottom (there is an outlet on the other side of the wall in the master bedroom). I removed the old box and put in a New Work box. I'll get some drywall on it tonight and put on a tape coat of mud.
Old 01-27-2013, 12:01 PM   #191
Trucon01's Avatar
Just a few before an after pics of the holes I patched. Also, an updated panel legend that shows the 2 new 20A bathroom recepts.
Let me know if anyone wants the template.
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-5.jpg
Old 01-28-2013, 06:53 PM   #192
Your fuse panel overlay is impressive! You put that together yourself?
Adrenalinejunky is offline   Reply With Quote
Old 01-29-2013, 08:37 AM   #193
Trucon01's Avatar
Thanks!
No, I saw a template online and then customized it for myself.
Brown = Basement
Blue = Middle floor
Orange = Top floor.
I plan on eventually keeping this place as a rental and wanted to do everything properly and organized.
PS -- Had my electrical box inspected. Everything passed!!
Old 02-09-2013, 06:25 PM   #194
Trucon01's Avatar
During the day, we got up the XPS foam on the front wall.
Old 02-09-2013, 06:27 PM   #195
Trucon01's Avatar
Toward the end of the day, we started to concrete over the french drain and around the sump pit. Used around 17 60# bags of sakrete high strength, all mixed by hand.
2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-4.jpg   2012 - Basement demo-photo-5.jpg   2012 - Basement demo-photo.jpg
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 07:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
