2012 - Basement Demo - Project Showcase - Page 12 - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 11:54 AM   #166
Ok I've never done pot lights before sheetrock. What way are you going to get the sheetrock flush with the lights?
rebelranger is offline   Reply With Quote
Old 12-11-2012, 02:17 PM   #167
Trucon01's Avatar
Rewards Points: 510
This was just testing them out. I will be removing the trim and bulb before I put on the drywall.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 12-11-2012, 03:23 PM   #168
Rewards Points: 202
Did you use LED trims? I want to use new construction cans with LED trims but everything I see online seem to be the retrofit kind.
benleef is offline   Reply With Quote
Old 12-11-2012, 08:11 PM   #169
Trucon01's Avatar
Rewards Points: 510
No, I used a regular trim. I got 6 for 53.00 at HD.
Old 12-31-2012, 12:23 PM   #170
Trucon01's Avatar
Rewards Points: 510
New sliding glass door installed.
Before:
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg
Old 12-31-2012, 12:24 PM   #171
Trucon01's Avatar
Rewards Points: 510
After:
2012 - Basement demo-photo-4.jpg   2012 - Basement demo-photo-5.jpg   2012 - Basement demo-photo-1-1-.jpg   2012 - Basement demo-photo-2-1-.jpg   2012 - Basement demo-photo-3-1-.jpg
Old 01-02-2013, 10:30 AM   #172
Trucon01's Avatar
Rewards Points: 510
Here is a shot at my current electrical panel configuration. Things will change, but after I routed everything, I noticed a few over loaded circuits. Can anyone guess which they are????
In any case, I'm going to try to run 12-2 wire down along the main vent into the basement and get 2 more dedicated lines to the attic to feed to the top floor.
Old 01-07-2013, 12:57 PM   #173
Trucon01's Avatar
Rewards Points: 510
While I was outside pounding in the ground rods from my electrical box install, I noticed my windows need re-caulked. Probably get to it in the next few days. Here are some before pictures.
2012 - Basement demo-photo-1-1-.jpg   2012 - Basement demo-photo-2-1-.jpg   2012 - Basement demo-photo-3-1-.jpg   2012 - Basement demo-photo-4-1-.jpg   2012 - Basement demo-photo-3-2-.jpg
Old 01-07-2013, 12:59 PM   #174
Trucon01's Avatar
Rewards Points: 510
Here are the ground rods so far... Never knew it would be this hard. I'm going to try to pound them in as much as I can and then possibly cut off what I can't get into the ground... Any suggestions on how to make it easier? I'm using a sledgehammer now.
Old 01-07-2013, 01:01 PM   #175
Trucon01's Avatar
Rewards Points: 510
More pictures of the stamped patio, by request from some readers.
2012 - Basement demo-photo-1.jpg   2012 - Basement demo-photo-2.jpg   2012 - Basement demo-photo-3.jpg   2012 - Basement demo-photo-4.jpg
Old 01-08-2013, 02:31 PM   #176
Rewards Points: 978
the patio looks really great. good stuff
whats the ground rod for?
federer is offline   Reply With Quote
Old 01-08-2013, 03:53 PM   #177
Trucon01's Avatar
Rewards Points: 510
On the previous page, you can see that I had my old 200A GE panel / breakers replaced by all new Square D QO stuff. Since this has a permit, I needed 2 ground rods. I only had the cold water bond.
Old 01-10-2013, 03:13 PM   #178
Concrete
Hey dO you have a contact number or email I have a question for the basement
thanks
ItsaDucati2012 is offline   Reply With Quote
Old 01-10-2013, 07:51 PM   #179
Trucon01's Avatar
Rewards Points: 510
PM me. I'll respond ASAP.
Old 01-10-2013, 08:30 PM   #180
sorry man it wont let me there is no PM tab
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 06:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
