1958 Ranch Home, Full Of Character - First Home, First Major Project - Project Showcase - Page 22 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 01-16-2012, 08:47 AM   #316
Thadius856's Avatar
Rewards Points: 504
A major milestone has been reached now that the center unit carcass is together!
Boy, was it difficult gluing this one together. I went from having 15 clamps big enough to clamp across the face to only 3 clamps because of the increase in size. Lots of clamp-shoot-unclamp-move-reclamp.
And now we enter the face frame phase of construction.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 01-16-2012, 08:50 AM   #317
Thadius856's Avatar
Rewards Points: 504
The wife's clearly happy to have her entry way, dining room, seating and table back. Sorry about the overexposure... the camera didn't like this one particular lighting situation. No idea why.
I took the 4 sawhorses to the shed, as well as several totes of materials. Some items were moved to the laundry room to clear this space back up (for now ).
Old 01-16-2012, 02:19 PM   #318
Originally Posted by Thadius856 View Post
Ok, so the "entertainment center" is looking a bit like a pile of devices and wires. Well, it is. Had to take down all the speakers to paint a few days ago, and they haven't gone back up yet. I'm waiting until my new mounts come in from Monoprice. I'm ordering today, I promise this time! There will eventually be a banana plug wall plate beside each mount as well, with in-wall runs of the speaker wire. For now, thumbtacks will have to do.
Being near-sighted, I figured a 60-65" TV at 8' was about what I wanted. The far-sighted one disagreed, leaning towards a 42". I ended up splitting the difference with a 50" 3D 1080p Smart TV (a great price point) and mounting it on one of the beefiest (and most expensive) mounts that Monoprice could offer. He thinks the TV is just the right size when against the wall, and when I'm alone I pull it 30" closer for a much more fulfilling experience.
Per Murphy's Law, the TV mount needed to bolt into two studs, and the TV ended up needing to be mounted 8" off center to either side of the room. Naturally, I chose away from the fireplace. I have plans for that area!
This is the seating, at nearly full recline. Even fully reclined, this set amazingly only needs about an additional 3" clearance to the rear as opposed to when seated upright. All 4 recline in the same manner, though one is currently blocked from being able to because of clearance.
This house really has come a long way. I really like that your "lower level" has been turned into a "game room" or sorts. Will you add more theater seating furniture or game room supplies to the space? (Sorry I tend to take an interest in the design element of a room).
We're in the process of finishing our basement (which is a wreck) and I like the hardwood you chose for the flooring in your house. Was it difficult to put in? If it came with the house, did you have to restore it?
Ozgirl1985 is offline   Reply With Quote
Old 01-16-2012, 02:35 PM   #319
Thadius856's Avatar
Rewards Points: 504
A long way into a ton of unfinished projects, maybe! Before any new projects start (to include picture frames ), I'm set on getting everything wrapped up, including floor transitions. It's going to take a while.
The hardwood came with the house. It looks to be the original flooring, and appears to have been refinished once. It was a fairly major selling point for us. It could probably use refinishing or replacement again, but there's not much point while we're still renovating.
If you're only as far into the thread as your quote suggests, I think you'll be pleastantly surprised to see how far that room has come... :D
Old 01-16-2012, 03:22 PM   #320
On the way back from my new favorite lumber supplier, I swung by Harbor Freight. I know some people here hate their products, while others love them. Myself, I feel that some products are well worth their price while other are completely garbage. Take for example the 18" and 24" bar clamps I bought. They don't have perfectly machined heads or super supply grips, but they easily get the job done with enough force to squeeze a glue joint dry. At $5 (I think?) everyday price for a 24" clamp, it'll pay itself off quickly.. and that's if you don't catch them on sale.
(Admittedly, they bend half-moon shaped when you clamp real hard, but they spring right back when released)
I took my receipt back to Harbor Freight for the clamps, from exactly 30 days prior, along with a stack of coupons. I got the $30/yr membership and the clerk was nice enough to backdate the member's sale price of the 24" clamps for me, putting $6 back in my pocket. I picked up a $40... rolling frame cart thing... for $25 because of the membership. Only $9 until I pay off the membership. It's proven to be an amazing buy. Here you can see the front (wheels on castors, or you can lock it stationary within seconds using the feet) and the rear (wheels on axles).
You don't happen to know the name or Item # for the roller stand do you? I'm looking for something like this for my table saw and can't for the life of me seem to find em on the HF website.
jtitus07 is offline   Reply With Quote
Old 01-16-2012, 08:09 PM   #321
Thadius856's Avatar
Rewards Points: 504
You know, the same thing happened to me, actually. And that was after I'd already bought one!
The product name is actually "300 Lb. Capacity Mobile Base". Not exactly the first thing that came to my mind either.
http://www.harborfreight.com/300-lb-...ase-95288.html
Note that you only get the four black corners. You need to supply and size your own wood down to 1" x 1" (or use steel tubing). It doesn't come with the stand in the picture.
They're $40 ea everyday price, so take a 20% off coupon from the Sunday paper with you if you can find one. Or, getting the $30/yr membership drops them down to $25 ea if you bring the Inside Track Club coupon from the January mailer: http://slickdeals.net/f/1276399-Harb...-Coupon-Thread
Old 01-19-2012, 08:20 AM   #322
Thadius856's Avatar
Rewards Points: 504
Not a whole lot got done yesterday. I'm taking the last test to complete my CCAF degree today, so I spent much of yesterday studying and will continue this morning. With a 30% pass rate, it has the lowest pass rate of any test I've taken so far for this degree. But again, it's a class I took in college and have some real world experience with, so I'm not terribly worried about failing... just getting a crummy score.
The carpenter finished building the mobile bases. There's now four installed: planer, large router table, radial arm saw and band saw. Everything's now easy to move into place and clean behind.
I spent a good few hours cutting a few fiddly bits of molding. You know those short pieces that take forever and don't add very much? Yeah, those ones.
Also pumped out the first tube of caulk behind the chair rail. This was a bit of a shortcut because when I started I had neither a table saw nor a router and did not have access to a traditional wainscoting cap. Thus, the chair rail was installed flush on top of the bead board and the gap filled with paintable white acrylic-latex.
(Please excuse these pictures... the flash washed everything out, but when I tried to turn it off, the camera refused to focus on what I wanted)
Used the last couple gobs to re-caulk between the bathroom tile and the bath tub, as well as along the bathroom baseboard. Will certainly need to pick up at least one more tube today.
Also cut a few pieces of quarter round (for inside corners) and L-shape moulding (for outside corners). Don't think I'm going to cope each profile like I tried last time... just too damn time consuming!
Old 01-19-2012, 10:52 AM   #323
Where did you learn to make the cuts for corners and what are you using?
Dinggus is offline   Reply With Quote
Old 01-19-2012, 01:25 PM   #324
Thadius856's Avatar
Rewards Points: 504
Miter saw set at 45. Used a Miter Box previously, and those cuts came out looking like garbage... I mean... it's yours for $25.
Edit: Obviously joking. It cut decently, but after the entry, living room and dining area, I was about to throw it out the window. Spent $50 at the Big Blue. Still sharp. Then I went on CraigsList and bought a Craftsman Miter Saw with new blade for the same price. Ugh, thinking about how much time I wasted...
I could have done a better job, if I wanted to protractor each corner, then compound each cut. No thanks. I'm just fine using caulking and spackle, thanks.
Old 01-20-2012, 04:45 PM   #325
Thadius856's Avatar
Rewards Points: 504
Yesterday was a long day. Spent most of the morning studying, as predicted. Played some Rocksmith to keep calm. Took my test, and passed with a 70/80. Once those credits evaluate, my AS requirements will be completed.
Also dropped some MDF pieces back off at Lowe's, picked up 76 ft of moulding and two tubes of caulking, took a busted sander (that took over two weeks to ship to me) back to Home Depot, got some card stock & cover stock from Staples, and shopped routers. Pretty sure I want a big 'ol 3+hp beasty, but still might go with a nice 2.5hp.
Old 01-22-2012, 11:18 PM   #326
Alright thanks! Wife is getting upset because I want to start another project while waiting on the kitchen. My buddy is flying in tomorrow night while he's on R&R as well, and we're going to go extremely hard on the kitchen.
Home Depot is coming Tuesday to talk about refacing, the staining looks good, but I'm moving to Ft. Hood like 2 months after I get back, so I need to get the kitchen done.
So, my next question is, I'm looking at patching a decent size hole I did in the laundry room on accident, if the dry wall is crumbling as I replace it, I told the wife I should just redo the whole laundry room with new dry wall. How hard is it exactly to put new dry wall up? Screw them in, mud over the cracks and screw holes, then paint?
My next question is, how hard is tiling? Also, the room you tiled was it your laundry room as well? If so, do you need a drain just incase of washer flooding?
After pulling up the laminate tiles off the floor, there is a lot of adhesive left. I'm debating to remove most of it, then just lay cement floor down for the tile.
Old 01-23-2012, 11:15 AM   #327
Thadius856's Avatar
Rewards Points: 504
Ok, let me try to tackle those. Normally, I'd use a drywall patch with a steel mesh for large holes (door knob size or larger) or without the steel mesh for smaller holes. But if the area to be patched is in poor condition, then a patch kit like that won't do much good. Before you rip down all of the laundry room, you need to realize that hanging the drywall is not the hard part! Between mudding it up and spraying texture, it's going to take a whole lot longer than you might think. Plus, I for one don't have a texture sprayer (and don't want to pay for one), and the learning curve has got to be horrendous.
The easiest solution, IMO, would be to cut the hole back to the center of the adjacent studs, then make it roughly square. That'll leave you with a hole approximately 16"x16". A 24"x24" piece of drywall can be found at the Big Blue or the BORG for maybe $4. Cut it down, screw it in, mud it up, and spray on some texture in a can (orange peel or knockdown texture to match). If the sheet is still garbage when you make the hole that big, then you're pretty much hosed into replacing the whole thing, and then yes, probably the rest of the drywall to match. That puts you square back in the realm of having to retexture the whole room.
I strongly suggest you consider hiring out mudding and/or texturing if you want a professional-looking job. Your first attempt will look like dog barf and eat up your R&R for little impact. The kitchen project is a much better place (and better return on investment) to put your time (and money). More directly, yes, it's as easy as you think it is, but it's terribly time consuming.
One last thing to consider on that drywall patch... I avoided having to texture and was able to hide my first attempt at mudding by putting up paneling. I just used the MDF beadboard, but Lowes/HD both have real wood and tileboard alternatives (though I've never worked with tileboard).
As for tiling... it was far easier than I thought it would be, but I also had the easiest setup imaginable (small room, tiling directly onto the slab). A straight 12" grid is about as simple as it gets. I have a tendancy to throw a ton of extra detail into my projects, and it adds considerably to the time. If I had just done 12's on a grid, I could have been done in a day of cutting, a day of mudding/laying, a few hours of grouting and a few hours of sealing. My 12's on diagonal / course of 6's / 12's on grid pattern took 25ish hours of cutting (cheapo tile saw), 30ish hours of dry fitting / laying, 2 hours of grouting and 2 hours of sealing. That's a lot for a 120 sq ft area.
Old 01-23-2012, 11:25 AM   #328
Already cut my hole out, doesn't seem to bad, so I'll easily replace it.
As for tiling, already bought all my supplies. Our laundry room is about 50sq ft., and I bought 3 boxes of 13x13 tiles. I'm going to do the straight method. My buddy told me use complete tiles in the most common entry ways, then towards the least walked through area which is near the back of the machines would need to be cut of course. I hear so many different methods, guess it doesn't matter which one I pick.
Old 01-23-2012, 11:30 AM   #329
Thadius856's Avatar
Rewards Points: 504
Your buddy seems to be steering you in the right direction.
It seems a lot of these simple DIY instruction get overly detailed when the pro's get into the mix. Their methods, while valid, are geared more towards a system where time is worth far more than the materials, and we tend to operate an opposite realm. Especially so if we're doing it because we enjoy it, not because it has to be done right now. There also seems to be a pretty big Holmes-on-Homes-syndrome going around, where anything that isn't 100% technically correct is automatically considered 100% applicably incorrect. What we're really talking about here is using wet mud to stick a piece of baked mud on to a slab of cured mud. If it lays even, doesn't crack and you can walk on it, how much can there be to it?
I will say that I wish I had used a better saw. I didn't save myself any money going with the cheapo saw, because it took way longer, made me freehand all of my cuts (the fence was worthless) and caused me to lose a $25 bag of heavily modified thinset, the $5 bucket I mixed it in, and (almost) the $10 stirring tool too. Plus the dump fees to dispose of that brick. And added a ton of stress, making much of the process less than enjoyable.
Old 01-23-2012, 11:55 AM   #330
Yeah, he's letting me borrow his wet saw tomorrow. So, I figured I can have the backer board laid down tonight and tile, then tomorrow I can make the final cuts.
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Attic insulation in ranch home lchilds72 Building & Construction 6 11-29-2008 11:04 AM
Anyone have a sample materials price list for 4br ranch home a re-wire job? ehoez Electrical 4 09-24-2008 01:00 PM
