1952 Brick Traditional Overhaul - Project Showcase - Page 13 - DIY Chatroom Home Improvement Forum
Old 07-24-2014, 11:07 PM   #181
shadytrake's Avatar
Rewards Points: 364
Today we got the load of pea gravel that we will use for the thermal mass. I also started to build the heater with refractory cement. It is coming together.
1952 Brick Traditional overhaul-img_1710.jpg   1952 Brick Traditional overhaul-img_1711.jpg   1952 Brick Traditional overhaul-img_1712.jpg   1952 Brick Traditional overhaul-img_1713.jpg
shadytrake is offline   Reply With Quote
The Following User Says Thank You to shadytrake For This Useful Post:
cocobolo (07-25-2014)
Old 07-25-2014, 10:26 PM   #182
shadytrake's Avatar
Rewards Points: 364
I'd like to pat myself on the back as I've never used refractory cement before and I think the heat riser looks pretty darn good.
The rocket mass heater will be ready to test as soon as the cement cures. Lots of photos.
1952 Brick Traditional overhaul-img_1716.jpg   1952 Brick Traditional overhaul-img_1717.jpg   1952 Brick Traditional overhaul-img_1718.jpg   1952 Brick Traditional overhaul-img_1719.jpg   1952 Brick Traditional overhaul-img_1721.jpg
Old 07-25-2014, 10:35 PM   #183
shadytrake's Avatar
Rewards Points: 364
More photos of the build.
1952 Brick Traditional overhaul-img_1726.jpg   1952 Brick Traditional overhaul-img_1728.jpg   1952 Brick Traditional overhaul-img_1729.jpg   1952 Brick Traditional overhaul-img_1730.jpg   1952 Brick Traditional overhaul-img_1731.jpg
shumakerscott (07-25-2014)
Old 07-26-2014, 12:17 AM   #184
cocobolo's Avatar
Rewards Points: 6,098
Looking pretty darn good there Melissa. I bet you can't wait for the big fire up.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 07-27-2014, 12:12 AM   #185
shadytrake's Avatar
Rewards Points: 364
Videos of the finished heat riser. Tomorrow we will put on the insulation tube and the barrel.
We got excellent temperatures.
http://youtu.be/xZuliqXkdRk
http://youtu.be/TwVylqxKyPE
http://youtu.be/xMDT9sZvz5M
http://youtu.be/qB5QlxBd6fE
http://youtu.be/MLuinF89nmI
1952 Brick Traditional overhaul-img_1741.jpg   1952 Brick Traditional overhaul-img_1743.jpg
cocobolo (07-27-2014)
Old 07-28-2014, 11:43 PM   #186
shadytrake's Avatar
Rewards Points: 364
Insulation tube completed and thermal mass fill is done. We will seal it tomorrow with concrete. Then all that is left are the barrel welds and the clean out access panel.
1952 Brick Traditional overhaul-img_1772.jpg   1952 Brick Traditional overhaul-img_1773.jpg
cocobolo (07-29-2014)
Old 07-29-2014, 01:46 AM   #187
Ole Wood Worker
BigJim's Avatar
Rewards Points: 526
Wow, that is impressive, you flat out did your homework (pardon the pun there) You have done a really good job, I would be proud of that for sure. It is interesting how it works, I would think the smoke would come back out the short feed chamber, but you proved it don't.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
shadytrake (07-29-2014)
Old 07-29-2014, 10:50 PM   #188
shadytrake's Avatar
Rewards Points: 364
Thermal mass DONE!! Tomorrow we build the shelves. Orchids may be moving in this weekend.
1952 Brick Traditional overhaul-img_1781.jpg   1952 Brick Traditional overhaul-img_1782.jpg
The Following 2 Users Say Thank You to shadytrake For This Useful Post:
BigJim (07-29-2014), shumakerscott (07-29-2014)
Old 07-30-2014, 10:59 PM   #189
shadytrake's Avatar
Rewards Points: 364
My hubby has some mad skills! Here is what he did today!
Tomorrow we install the exhaust fan and possibly start the panels! Home stretch!
1952 Brick Traditional overhaul-img_1786.jpg   1952 Brick Traditional overhaul-img_1787.jpg   1952 Brick Traditional overhaul-img_1788.jpg   1952 Brick Traditional overhaul-img_1789.jpg   1952 Brick Traditional overhaul-img_1790.jpg
cocobolo (07-31-2014)
Old 07-30-2014, 11:02 PM   #190
shadytrake's Avatar
Rewards Points: 364
Here are some pictures from the garden. Baby cantaloupes and dragon cayenne peppers.
1952 Brick Traditional overhaul-img_1783.jpg   1952 Brick Traditional overhaul-img_1784.jpg   1952 Brick Traditional overhaul-img_1785.jpg
BigJim (07-30-2014)
Old 08-01-2014, 11:45 PM   #191
shadytrake's Avatar
Rewards Points: 364
Oh the DETAILS!!! I spent the day installing custom items. Where do I start?
I ran all of the 1/2" PVC for the faucets and my foggers. I only have one fogger assembly so far as I wanted to test it. But, I anticipated that I would like them so I planned for four total so they are just capped at the moment. They work pretty well, but I did have a few drips. It is still a work in progress. Total cost was $25 including the fogger assembly.
The next custom item came to me while I was at a horse show. The wash rack had an overhead boom system to keep the horses from stepping on the hoses. One of the things that annoys the heck out of me is the hose on the floor. I didn't want to pay $80 for a boom kit either, so I made my own. Total cost $25. Not too bad and even if the hose is left hanging, it does not pile up on the floor.
Then I had to devise a drain for the sink as ours cannot take a standard sink tail. I ended up having to use a myriad of parts to get it to work. Six total trips to Lowes!! Total cost $9.
I completed these custom items by myself. Hubby spent the day cussing over the instructions for the exhaust fan and putting silicone on the panels. TIP - having the panels taped or clamped together makes siliconing quick and easy.
Photos!
1952 Brick Traditional overhaul-img_1820.jpg   1952 Brick Traditional overhaul-img_1822.jpg   1952 Brick Traditional overhaul-img_1823.jpg   1952 Brick Traditional overhaul-img_1824.jpg   1952 Brick Traditional overhaul-img_1814.jpg
Old 08-01-2014, 11:46 PM   #192
shadytrake's Avatar
Rewards Points: 364
more photos
1952 Brick Traditional overhaul-img_1830.jpg   1952 Brick Traditional overhaul-img_1826.jpg
Old 08-02-2014, 01:31 AM   #193
Ole Wood Worker
BigJim's Avatar
Rewards Points: 526
Wow, y'all have been busy, looking good.
Jim
Old 08-08-2014, 12:09 AM   #194
shadytrake's Avatar
Rewards Points: 364
The greenhouse is done! We won't test run the RMH again until the fall, but here are the pictures of our finished project.
1952 Brick Traditional overhaul-img_1893.jpg   1952 Brick Traditional overhaul-img_1894.jpg   1952 Brick Traditional overhaul-img_1895.jpg   1952 Brick Traditional overhaul-img_1897.jpg   1952 Brick Traditional overhaul-img_1898.jpg
Old 08-08-2014, 12:12 AM   #195
shadytrake's Avatar
Rewards Points: 364
And more photos of the completed project.
1952 Brick Traditional overhaul-img_1920.jpg   1952 Brick Traditional overhaul-img_1921.jpg   1952 Brick Traditional overhaul-img_1922.jpg   1952 Brick Traditional overhaul-img_1927.jpg   1952 Brick Traditional overhaul-img_1928.jpg
wrought iron security door frame diy888 Windows and Doors 6 02-22-2016 07:08 AM
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 08:09 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
