1935 Cottage, New Kitchen - Project Showcase - DIY Chatroom Home Improvement Forum
Old 12-24-2014, 03:50 AM   #1
Rewards Points: 264
1935 cottage, new kitchen
I'm using part of the Christmas break to get most of the structural work done on this project, which involves a new kitchen addition to replace the current 1950's one that is too small and has really had its day... the old kitchen will become a dining room. I have the cabinets & tops from a nice kitchen that my uncle replaced during renovations a couple years back, so the new space has been designed so that (hopefully) the existing cabinets fit without too much modification
3 days work got the foundations & subfloor done, including inspection of the footings before the concrete pour. I will carry on after Christmas.
1935 cottage, new kitchen-dsc04625-resized.jpg   1935 cottage, new kitchen-dsc04627-resized.jpg   1935 cottage, new kitchen-dsc04628-resized.jpg   1935 cottage, new kitchen-dsc04629-resized.jpg
mgp roofing is offline   Reply With Quote
Old 12-24-2014, 05:49 AM   #2
DIY staff
Rewards Points: 6,700
Nice project--where are you located? Most places in the U.S.A. do not allow buried posts---interesting to see that style of construction.
Old 12-24-2014, 06:55 PM   #3
Rewards Points: 264
I'm in New Zealand--this is standard construction practice here--the posts are treated for ground contact & set in concrete. Most new construction uses slab on grade nowadays--less labour intensive to construct & closer to ground level, which is important in heavily built up areas, where shading of neighbouring properties by buildings can be an issue.
The Following User Says Thank You to mgp roofing For This Useful Post:
oh'mike (12-26-2014)
Old 01-06-2015, 02:47 PM   #4
Rewards Points: 264
I've made a lot of progress since I last posted, got the walls & roof framed & plywood laid. Working on the roof coverings now, TPO for the new roof & going to re cover the low slope metal roof seen in the pics with ply & TPO, as I can see problems happening in the future. I had the building inspector out yesterday, he was impressed with my workmanship
1935 cottage, new kitchen-dsc04642-resized.jpg   1935 cottage, new kitchen-dsc04644-resized.jpg   1935 cottage, new kitchen-dsc04656-resized.jpg   1935 cottage, new kitchen-dsc04658-resized.jpg   1935 cottage, new kitchen-dsc04660-resized.jpg
Old 01-06-2015, 04:14 PM   #5
DIY staff
You have been busy---it is interesting to see the style of framing you used---
Very different that ours--we have heavy snow loads up here.
Old 01-07-2015, 01:13 AM   #6
Rewards Points: 264
We never have snow here--I have done roofing jobs in snow areas so I have seen the heavy framing that is needed to take the weight.
Old 01-07-2015, 03:16 AM   #7
Rewards Points: 264
Today's project was to do the tie-in to the existing corrugated metal roof over my office; once I started, I decided to carry on & sort out all its other issues--rusty flashings, leaks, and the draughty, un-insulated area that was originally an outside porch, that someone closed in & made a small hallway to the office. It was also 20mm lower than the office roof framing; that was a bonus since bringing the roofs to the same level allowed more depth for insulation. I also replaced the shingles I removed to lay the TPO.
1935 cottage, new kitchen-dsc04664-resized.jpg   1935 cottage, new kitchen-dsc04665-resized.jpg   1935 cottage, new kitchen-dsc04666-resized.jpg   1935 cottage, new kitchen-dsc04667-resized.jpg   1935 cottage, new kitchen-dsc04668-resized.jpg
Old 01-07-2015, 03:19 AM   #8
Rewards Points: 264
More pics
1935 cottage, new kitchen-dsc04671-resized.jpg   1935 cottage, new kitchen-dsc04669-resized.jpg
Old 01-07-2015, 05:33 AM   #9
DIY staff
Much better---
Old 01-07-2015, 05:53 PM   #10
Rewards Points: 1,370
I'm not into these smiley faces and all, but looks great, so this pretty well sums up my thoughts...
Old 01-09-2015, 03:22 AM   #11
Rewards Points: 264
I now have most of the fascia & soffits done, and the house wrap on, despite interruptions to work resulting from the cold faucet in the old kitchen springing a leak; it is now disconnected & the pipe capped since the mechanism is seized--attempts to dismantle for washer replacement a couple of months ago were not successful.
And the neighbour's cat decided to leave its recently born kittens in my spare bedroom while I wasn't looking...had to make 2 separate trips taking them back to the neighbours to be reunited with Mum
I also removed the old laundry window & the wall below to allow access into the new space--the opening will become a linen cupboard later in the project--once the wiring has been rerouted around the opening.
1935 cottage, new kitchen-dsc04677-resized.jpg   1935 cottage, new kitchen-dsc04675-resized.jpg   1935 cottage, new kitchen-dsc04678-resized.jpg
123pugsy (01-09-2015)
Old 01-29-2015, 02:31 PM   #12
Rewards Points: 264
I now have all the siding done; I reused most of the existing since it was still in good condition. I also had some leftover from when I had the house moved onto the property originally, that I used. I uncovered a few surprises in the existing walls,the worst being that old bathroom window that had been relocated by whoever built the previous addition to the left of it--that is a load bearing wall Also, the original galvanized water pipe for the kitchen sink (abandoned long ago & replaced with copper); and that foam insulation shrunk rather a lot as it cured; thankfully only about 1/4 of the house has it, the rest has fibreglass mostly installed by myself--the foam was a previous owner's project. There's also going to be some extra work dealing with the wall where the house had been cut & then joined back together after being moved.
1935 cottage, new kitchen-dsc04691-resized.jpg   1935 cottage, new kitchen-dsc04697-resized.jpg   1935 cottage, new kitchen-dsc04684-resized.jpg   1935 cottage, new kitchen-dsc04685-resized.jpg   1935 cottage, new kitchen-dsc04686-resized.jpg
Old 01-29-2015, 02:34 PM   #13
Rewards Points: 264
More pics
1935 cottage, new kitchen-dsc04689-resized.jpg   1935 cottage, new kitchen-dsc04690-resized.jpg   1935 cottage, new kitchen-dsc04693-resized.jpg
Old 01-29-2015, 06:32 PM   #14
DIY staff
Coming along nicely---How old was the original house? 1940s?
Old 01-30-2015, 11:50 AM   #15
Rewards Points: 3,331
In post seven, it appears the roof has no ventilation.?
That would make it a hot tin roof.?
ron45 is offline   Reply With Quote
Tiling kitchen - Subfloor has a hump. Bigmo59 Flooring 10 09-10-2014 10:29 PM
Kitchen, Dining Room, Pantry mprice214 Electrical 23 07-14-2014 11:45 AM
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
