Xl 80trane - Appliances - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 07:01 PM   #1
Xl 80trane
It flash 3times I know can be pressure switch I checked the pressure switch and is working ok and also I replaced the inducer motor and still having the same problem .
Sarco is offline   Reply With Quote
Old 10-25-2012, 07:12 PM   #2
Unhappy
[quote=Sarco;1037984]It flash 3times I know can be pressure switch I checked the pressure switch and is working ok and also I replaced the inducer motor and still having the same problem all the wires are ok there to loose wires the inducer motor work ok but there is no heat and the same error is there a way to reset the error?
Old 10-25-2012, 07:14 PM   #3
[quote=Sarco;1037993]
