WP Over Range Installation - Appliances - DIY Chatroom Home Improvement Forum
Old 01-20-2015, 09:21 AM   #1
Rewards Points: 4
WP Over range installation
Just installed a WP over range microwave and everything works and looks good except it wont get hot. Any suggestions?
macollins1225 is offline   Reply With Quote
Old 01-20-2015, 09:35 AM   #2
Everything works? Except for the main component the magnetron . The problem is in the oven. If it's new, I would just return it as defective otherwise you will need to have it repaired. Could be as simple as loose connection in the machine, a bad control board, bad a magnetron etc. probably not worth fixing if you need to pay someone to repair it. If you attempt it yourself I would find the service manual. There are some very high voltages in a microwave oven you want to make sure everything is put together correctly
jimn01 is online now   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
macollins1225 (01-20-2015)
Old 01-20-2015, 11:42 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,274
call for warranty service, if you touch it you void all warranties
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
Old 01-20-2015, 07:06 PM   #4
Rewards Points: 747
Please forgive me in advance. I do not mean to be insulting. What do you mean
it wont get hot.
? Have you tried a cup of water inside the unit and hitting the right buttons? I think it is cook time, 200, start.
The manual that come with these is not the best I have ever tried to read. BTDT.
Colbyt
Colbyt is offline   Reply With Quote
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
120v gas range wiring question Redfishjoe Electrical 5 05-11-2011 09:37 PM
range fan installation question Jeremy Hillary Boob, PhD Electrical 3 01-15-2009 04:06 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Range hood installation, termionating at ceiling gorf Appliances 3 12-04-2008 09:28 PM
