Woodstove - Repeated Clogging Pipe. - Appliances - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 08:29 AM   #1
Woodstove - repeated clogging pipe.
How do I keep the smoke from the stove from entering back into the house? The catalytic converter is one year old and I have cleaned the pipes. Does anyone know what is causing the smoke to enter back into my house? Thank you.
James2525 is offline   Reply With Quote
Old 02-16-2012, 09:01 AM   #2
Rewards Points: 3,130
From where is it entering the house?
Old 02-16-2012, 09:04 AM   #3
Rewards Points: 14,010
Not enough draft due to the way the chimmney was done is one cause.
Burning pine will soot it up fast and may cause a chimmney fire.
More detail and a picture inside and out may help someone here figure it out for you.
Old 02-21-2012, 08:13 AM   #4
Do you know where it is coming in from? Does it happen every time? Is it a stove or an insert? Is the chimney lined? Is the liner insulated? Is the chimney exterior or interior?
It is quite common for smoke to come in from the outside through windows, doors etc. due to atmospheric conditions. When you smell smoke in the house go out and look at what the smoke from the stove is doing when it leaves the chimney (you may have to do this right after you load it to see any smoke).
For instance, yesterday I loaded up my stove and took the dog for a 10 minute walk, on my way back to the house the smoke was coming right out of my 24' chimney and dropping straight to the ground. Opening the door lets the smoky smell in. After 20 mins there was no smoke to worry about.
If you ask your question at hearth.com there will be many folks willing to help I'll bet.
onion is offline   Reply With Quote
Old 02-23-2012, 01:23 PM   #5
Yes go to hearth.com and ask them. Sounds like it could be a downdraft? The air is getting sucked in because of negative air pressure in the lower portions of the house.
http://en.wikipedia.org/wiki/Stack_effect
Weird_T_Figure is offline   Reply With Quote
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Working with B-Vent pipe for WH vent BobN HVAC 16 01-25-2012 11:58 PM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 12:49 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
