-   -   wiring for electric range (and a little plumbing too) (http://www.diychatroom.com/f47/wiring-electric-range-little-plumbing-too-81655/)
forresth 09-17-2010 02:17 PM
I have not yet purchased my new oven, but I want to get the electrical ready.
My understanding is I need #6 (or maybe just #8) gauge wiring with 2 hots a neutral and a ground, and a 4 prong outlet with 1 round and 3 vertical prongs. and a 50 amp breaker.
I plan on also running new water and a drain line for the dishwasher and layndry washer going on the same wall. is there a minimum distance between these water using apliances and a the high amperage outlet?
Are these outlets generally placed up a bit higher to keep them dry?
nap 09-17-2010 04:30 PM
#6 wire for 50 amp
no separation requirements
most ovens have a recessed area in the lower rear to allow for the plug so it doesn't keep the oven away from the wall. Last one I remember, it seems like I had to place the recep as low as I could.
hang on for a few of the other guys that do resi work. In commercial, I don't deal with a lot of oven receps such as this.
forresth 09-18-2010 11:25 PM
I took a peak behind some oven at the store. you are right, they all had large recess at the bottom.
Daniel Holzman 09-19-2010 09:09 AM
My electric wall ovens (one is an Advantium and one is a GE 30 inch wide) were designed to be hard wired to a J Box, no wall plug. That may have been an option, don't know, but in any case I directly wired both of them to their own circuits. Both were 220V with 120V controls. The Advantium required 30A, hence #10 wire, while the oven only required 20A (#12 wire). My cooktop was 40A, hence required #8 wire, also no plug.
I believe some of the European models do not use 120V controls, hence would only require two hots and a ground. I suggest you buy your oven first, then figure out what type of wiring you need.
forresth 09-19-2010 10:54 PM
pretty sure ranges come without a plug so you can get the correct plug for your outlet. Makes sense that a wall oven could be different because they are a bit more permanent. In general, I like building for the future. In this case, that means I won't have to rerun all new wires when the upcomming cheap oven dies at the most inoppertune time. I did pick up some #6 4 wire and a 4 way range outlet, but I started thinking "why not run a sub pannel if you want to run a 50 amp circut anyways, the old box is running out of space for all these dedicated circuts anyways" :whistling2:so I'll have to look into that aspect now.
jerzeedivr 09-27-2010 04:43 PM
white wire
I would run a white wire because the 120 v. clock and light need a N. and if you change out the range later its there.
