Wiring An AC Induction Motor - Appliances - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 08:13 PM   #1
Question
Wiring an AC induction motor
Hi there, I just recently purchased a new motor that I was planning on using for a project. However, there was no instruction manual and trying to find information on the manufacturer's website has yielded nothing.
In short, I need to know how to properly wire up this motor so I don't burn it out.
Details :
A/C induction motor - split capacitor
Emerson model : K55HXHJT-4626
H/P : 1/10
Voltage : 120
Hz : 60
Amp : 1.4
Phase : 1
RPM : 1135/970
I have three contact wires, red, yellow, and blue.
Red to blue - 16 Ohms
Red to yellow - 15 Ohms
Blue to yellow - 30 Ohms
Ultimately, I intend to have this wired into a small switch box. Thanks for your help.
Passerby is offline   Reply With Quote
Old 02-16-2013, 09:45 PM   #2
Missouri Bound's Avatar
No markings on the wire? The red and blue are for the two speeds, and the yellow is the common. That's a generalization. The blue would be the ower speed, and the red the higher. You cap off the one you aren't going to use, unless you are using a switch to operate it at either speed. I suggest you contact where you bought it from to verify my suggestions....or take it to a motor shop and ask them.
Do you want it your way or the right way?
Old 02-16-2013, 10:44 PM   #3
I tried your suggestion. It works just fine. Thank you very much.
To the hardware store!
Blower Motor Wiring Help atvguy64 Electrical 11 08-14-2015 09:02 PM
Wiring question OR I don't want to fry my motor! unklerichie Electrical 15 12-09-2012 09:04 PM
Heat pump motor wiring 70sixspeed Electrical 2 10-29-2011 12:21 PM
Blower motor: Emerson to GE threeonesix HVAC 12 08-25-2011 03:59 PM
Wiring a Haldex pump and motor on a 2 post lift 69malibu Electrical 9 08-17-2011 12:00 AM
