Window Unit Air Conditioner Help? - Appliances - DIY Chatroom Home Improvement Forum
Old 07-26-2007, 10:02 AM   #1
window unit air conditioner help?
Hi everybody! I'm a newbie here... I have a window unit air conditioner in the hottest room of my house that spits water when I set it below 80 degrees... The unit drips water out of the back (outside), has the proper tilt on it and it does just fine when it's at 80 degrees (it's currently mid 90s outside now), but I would prefer it to be running at 72... I don't remember the brand of the air conditioner, but I have 2 others exactly like this one, and they don't have any problems...
Anybody have any suggestions?
Thanks!
greenvorlon is offline   Reply With Quote
Old 08-03-2007, 11:50 AM   #2
Rewards Points: 530
Even if itis dripping out the back, I would still check the cage for debri that may be parially blocking daming the water allowing some to get in house. Also, some window units will not drip out the back. They have a ring built on the condensor fan to sling water to help dissipate the heat. Supposed to help save energy.
Any advice on a good brand of air conditioner (window model) ? nubee Appliances 2 06-12-2007 03:24 PM
Need help with heat/cool unit before wife kills me buddyc1 HVAC 4 06-06-2007 11:15 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
Window air conditioner pwallyp Electrical 3 03-10-2007 10:04 AM
Window AC unit problems, Please assist if you can! Boscy HVAC 1 07-28-2005 10:58 PM
