Window A/C Support Bracket Installation. - Appliances - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 10:25 PM   #1
Window A/C support bracket installation.
I have a Thermwell Frost King ACB160H Air Conditioner Window Support bracket that I have had for a year or so. I seem to have misplaced the instructions and I am ready to install it. All I have is this picture.
It came with 4 plastic shims for the sill and 2 pieces of bracket. I don't know if I am supposed to use the shims. I know I am supposed to drill 2 to 4 holes in the outside of the window sill where the bracket top anchors to the window. The other part of the bracket has a rubber foot and rests against the house siding. There are several holes in the bracket to allow adjustment of the bracket to fit the house and to level it.
I searched the Internet for the instructions, but had no success.
http://www.drillspot.com/products/31...Stl_AC_Support
I seem to remember the original instructions saying that I should adjust the bracket so that the A/C unit will slope slightly away from level. I have metal clad windows, so I don't want to drill into the sill until I am confident about what I am doing. Also, I can't remember if it came with rubber washers to seal the holes drilled in the sill or if I am supposed to use silicone. Can anyone give me more help with the installation instructions or tell me where I can find some on the Internet?
Roy Rowlett is offline   Reply With Quote
Tags
window support bracket
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Retrofit Window Installation typerr Remodeling 4 10-28-2009 11:47 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Another window installation question edwood79 Remodeling 3 11-15-2008 01:14 PM
